Question about eMachines E19T6W 19" Widescreen LCD Computer Monitor Display
Monitors screen will blacout for a minute then it will come on showing auto processing icon. why does that happen
    Top Expert:
  • 14,553 Answers
What is happening if you remove it and the unit connected to it from power and then power back?
This is a monitor and have you tried it on another unit?
Posted on Dec 07, 2012
How to let boot screen show on external monitor
Press Fn key and hold, now look for the icon that shows laptop and monitor screen on the top F keys and press this will switch to external monitor.
May 27, 2012 | Compaq Presario Computers & Internet
Why does Sony laptop screen stays black when booting?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Mar 31, 2012 | Computers & Internet
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
Volume Icon in Appears on the Screen
if you know how to open it its simple replace the switch botton on your monitor replace all
Nov 03, 2008 | Acer AL1714 17" LCD Monitor
Blank Screen problem!
perhaps you toggled off the moniter... look on your keyboard for a monitor icon.... it happens alot
Robert
Aug 28, 2008 | Compaq Presario X1000 Notebook
Gateway fpd1530
Not sure about these screens but they should be button on the front that says auto. Press this and the screen should set itself up optimally. Usually does but I have not seen one of these before
Mar 07, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Can't manually adjust color
I happen to have an Acer Monitor although a later model. It has 4 buttons....one of these is the auto adjust and one other is the window that has manual controls (so to speak). If you look at it carefully...(and it should stay on the screen for at least a minute - they believe you will do something in that timeframe)...you will find a set of icons at the top. These are suppose to be visually intuitive (and they are after you have used them once or twice)....anyway, if you really want to set your colors manually and or make other adjustments....alignment et al...you use the other buttons when the manual control screen is there. Experiment a bit and you will discover what does what. FYI...all "modern" monitors have this ability....the icons differ....but autoadjust does the best job in general....personal preferences and eyesight withstanding. Good luck....a small glass of wine sometimes helps the process and reduces the frustration level the first time around.
Jan 24, 2008 | Acer AL1916W 19" LCD Monitor
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
By
Murugeshkumar.k
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor message
hello this is nichu ,your monitor is not supporting your cpu .hence you are getting the message "processing auto config message from screen display".either you have to change your monitor or you have to change your cpu.next time while purchasing the pc get the help your hardware vendor to check out the compatibility
Nov 04, 2007 | Gateway FPD1530 15" TFT LCD Flat Panel...
eMachines E19T6W 19" Widescreen LCD Computer Monitor Display Logo
60 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
