Question about Sony Alpha Dslr-a700 Cf Pin Connector Repair Service
Where can I find the part number for SONY ALPHA DSLR-A700 CF PIN CONNECTOR
How hard is it to replace?
  • annie Dec 15, 2012
    actually, found out it is considered an 'internal part'... Sony will not give a part number.
  • 685 Answers
Try your Sony retailer. Any reputable retailer should be able to help you with parts and accessories.
Posted on Dec 15, 2012
Sony DSLR-A100 eroor 0x58
Well, the good news is that there's probably no fault with the camera itself. It could be something as simple as the CF card being pushed in the wrong way. A look through the user manual will likely help you get to the bottom of your issue:
Sony Alpha DSLR A100 manual
Aug 13, 2014 | Sony Alpha DSLR-A100 Digital Camera
I need to buy a CF PIN CONNECTOR. Do you know where i can buy the part?
Sony like to call this assembly the "MM-076 Board" if it is not soldered directly to the main PCB of the camera. I just checked the service manual and it looks like it is soldered to the PCB, so you will have to unsolder every pin and solder on a new one. Thankfully CF is all the same so this part should work for you:
http://www.darntoothysam.com/products/Canon-EOS-Rebel-300D-SLR-Compact-Flash-CF-Card-Reader.html
Hope this helps.
Thomas
Jul 24, 2011 | Sony Alpha DSLR-A100 Digital Camera
A700 flashing "lens" message
Is the lens switched to manual as well as the mode dial. If the compatable lens is a minolta requiring an M42 adapter make sure that the protruding arm/rod is operating the shutter when depressed and that the adapter when fitted operates the lens when turned from auto to manual. Good luck.
Jun 27, 2009 | Sony Alpha DSLR-A700
I lost amual for my SONY a10... can't remember exactly how
Click Sony Support and download required instruction manual of Sony DSLR-A100
Mar 20, 2009 | Sony Alpha DSLR-A100 Digital Camera
Can not upgrade firmware v1 tov4 in a Sony a200.
there is know update in firmware for a 200 the v4 update is for the a700
Mar 16, 2009 | Sony Alpha DSLR-A200 Digital Camera
MY MEMORY CARDS NO LONGER WORK IN MY SONY DSLR A100 CAMERA?
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.
Best regards - Michael
Jan 12, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
I can't format any memory card (CF) with my Sony Alpha 100
you have a lock on your memory card check that !!
Jan 03, 2009 | Cameras
Cf card reader sony a 100 dslr
Buy a camera that does not use CF. Time to upgrade.
Nov 12, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha Dslr-a700 Cf Pin Connector Repair Service Logo
65 people viewed this question
Top Sony Photography Experts
JP Services
JP Services
Steve
Ed Mac
Are you a Sony Photography Expert? Answer questions, earn points and help others
