Question about Roland Music
Roland Boss GT6
I've been given one of these by a friend. He knows that two of my kids are really enjoying playing their guitars. It's powering up and all the dials and controls seem to be working - display is changing anyway. Trouble is there is no output. Not even a clonk when we plug the amp cable in. I'm trying to find a schematic for this so that I can trace the fault and my boys can start to use it. I've had a look on the internet and found lots of copies of the manual but no schematics. Can anybody help? My two older boys are both guitar daft and they would love to have this working. many thanks
danforddan1
  • 192 Answers
SOURCE: amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Posted on Apr 19, 2009
  • 5603 Answers
SOURCE: my guitar won,t play threw the amp lots oof static
The things to check arre FIRST the cable. These often have breaks or bad connectors. Replace with known good one and try it.
Next are the jacks on the guitar and the amp. These go bad and wiggling the KNOWN good cable at each end will flag which or both being bad.
Next are the switches and potentiometers in the guitar. Use some CRC226 sprayed into the pot and switch contacts... use sparingly...
The key is to find which thing or things are bad.
Posted on Sep 15, 2009
  • 417 Answers
SOURCE: My MT-2 wont distort my guitar.
A few things to try....
Usually the adapter will over ride the battery when used.
1) Make sure your 1/4" cables are working properly without the pedal "in-line".
2) Take out battery, and use just the adapter only. Make sure it is the correct and proper adapter that works with Boss. Usually the PSA-120. If you are not using a Boss Adapter, make sure yours is a direct replacement with same specifications. 9V/200mA. And "tip negative". DO NOT use Radio Shack stuff, nothing against them, but there adapters just don't mix well with Boss products and the like.
2) Try just the battery, no AC adapter. Remember to unplug the input when not in use. Saves battery.
Basic rule of thumb...when using correct AC adapters for all your pedals all the time, and all sounds good, then take out the batteries.
If you still experience problems, it would be an internal IC chip most likely. From there post another question maybe.
Posted on Apr 01, 2010
  • 5 Answers
SOURCE: my line 6 spider III 15 watt amp isnt working
While it could be true that you're having a problem with the guitar or cable as the previouse expert suggested, to say that it can't be anything else is false. It could be a jack problem...it would only be apparant when the jack is making contact with a cable. I do think you should test it with another guitar and another cable but if that is not solving the problem then I bet it's a problem with the input jack of the amo itself or even one of the ionternal components (this is a digital amp and there are MANY components and settings that can trigger a problem like this) If the problem is not solved with a new cable/guitar configuration then it's time to take it to the shop.
Posted on Mar 02, 2011
SOURCE: I've owned a Roland AC-90 acoustic guitar amp for
Fred, thanks so much.
I finally got an XLR-TRS adapter (I live in a small city in Brazil, only way to buy it here is ordering online then sit and wait, :-)) and tested. Got the output I was expecting and also the Phantom Power - I'm no technician but now I pretty sure the problem is this combo XLR/TRS jack. I'll try to find someone to open and replace it. But for now, the adapter will do the trick.
Thanks again!
Posted on Nov 28, 2011
My Boss ME-70 han only two dots when i power on ,pedals dont lit when i press it down, is there a solution with this?
PDF]BOSS ME-70 Training Guide - Roland
cdn.roland.com/assets/media/pdf/ME-70_Training_Guide.pdf
AC adaptor. • $418.50 List, $299 MAP ... Connect the ME-70 to power using a BOSSPSA-120S AC Adaptor. 4. Plug a guitar into the ... For illustration only ). 4. Press the ...1. Turn the MODULATION TYPE knob to select a Modulation effect. Do not ... 2. Pressboth pedals down again or press EXIT to return to Manual Mode.Missing: han ‎dots
ME-25 Guitar Multiple Effects Review ' Boss ' Guitar Effects ...
https://www.ultimate-guitar.com/.../boss/me-25_...
Ultimate Guitar Archive
Rating: 8.6/10 - ‎135 votes
Sep 16, 2015 - Overall the effects are very very full sounding and don't sound too digital by any means. ... With 2 selector pedals, up and down, its a pain in the ? ... Editing the patch is as simple as press 2 buttons at the same time and turning ... If this was stolen I would probably get the ME-70 just because it pretty much ...
Tom Scholz's Guitar Sound - Van Halen Links.com
Jan 06, 2016 | Roland Boss ME-70 Guitar Multiple Effects...
How do I connect my Boss CE-5 pedal for stereo?
Quite simply connect each output to its own guitar amp or use two mono or one stereo DI box and connect to stereo PA.
Sep 25, 2014 | Roland Boss CE-5 Chorus Ensemble CE5...
Non-working Boss GT 6 project for my kids.
Request the schematic diagram directly from Roland.
Dec 08, 2017 | Roland Boss Gt-10 Guitar Effects Processor...
Roland Micro Cube Amp fuse blew out. How do you fix it?
have a look here:
http://www.ehow.com/how_8698510_fix-roland-cube.html
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
Jan 11, 2012 | Roland Micro Cube Battery Powered Amp...
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
Hello - I have a Boss RC-2 Loop Station. While I enjoy the pedal's capabilities, it almost always creates an unwanted hum and sometimes an electronic pulse in every amp I use it with. (I typically keep...
Make sure the power supply for this is powered from the SAME receptacle as your amplifier is powered. Keep the cable from this to the amp fairly short and high quality cable. Keep guitar away from magnetic field sources... the wall wart adapters are notorious for generating magnetic fields.
Jul 20, 2011 | Roland Boss RC-2 Loop Station Stompbox...
Brand new chromatic tuner tu-3 pedal, plugged guitar into input and it powers on. Guitar plays through the amp, but when I hit the footswitch the check light and tuning bar do not light up.
Change the battery first. It could be dying and just barely have enough power to come on at first, but not to do anything else. If that doesn't solve it, you've got a defective one and you can go exchange it.
Feb 24, 2011 | Roland Boss Tu-3 Chromatic Tuner Tu3...
Music Logo
56 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
