Question about Plumbing
Aerator on Delta Kitchen Sink Faucet does not unscrew
The aerator is flush with the bottom of the spout, so there is nothing to grab and unscrew
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Check outside perimeter of airaitor,there should be two notches opposite of each other. example, 3 oclock and 9oclock. use a quarter or similar object , lay across two slots and simply unsrew
Posted on Dec 21, 2012
4 Suggested Answers
  • 74 Answers
SOURCE: No water pressure in kitchen sink. Not the aerator.
First of all we like to check the easy/cheap things first.
1. Are the shut-off valves closed lightly?
If they are closed, open them.....easiest fix of them all.
2. If the valves are open then possibly a washer is shifted.
Turn off the water supply at the valves under the sink. Remove the handles by removing the set screw under the handles. There should then be a packing nut which holds all of the "guts" of the faucet in. Remove this nut and pull out the long stem. On the bottom of this stem is a flat washer that may have been damaged or is just slightly shifted. EIther way, I would replace it if the faucet is more then a few years old as it is cheap and you already have access to it. WHen replacing the valve stem, be sure to use a plumbers grease on all rings and seals. The rest of the replacement is the same are the removal.
Hope this helps.
Posted on Apr 25, 2009
  • 111 Answers
SOURCE: I have a delta kitchen faucet model 172 and the
delta customer service or a plumbing supply house
Posted on Jan 29, 2011
SOURCE: how do you unscrew the aerator housing from the
If you look closely at part 25a, you will find two flat spots on each side of the ring. Clamp those flat areas with vice grips and turn.
Posted on Feb 04, 2012
How do I repair a kitchen sink diverter?
It sounds like there is just trash in the aerator just unscrew the aerator on the end of the spout and clean it out or replace it
Sep 30, 2016 | Plumbing
Water shoots out of my faucet, now can I plug it?
water is supposed to come out of your faucet...in a controlled fashion....if its at the handle....remove the handle and locate the source....tighten the packing gland or replace a seal. if it sprays all crazy at the spout...try unscrewing the little piece on the tip of the spout (aerator)....flush your faucet by running the water with it off...then flush out the screen on the aerator and re-attach it...hope I was some help....good luck and always know where and how to turn your house water supply off before working on any pressure points on your water supply system.
Oct 19, 2014 | Price Pfister Marielle Kitchen Faucet with...
Faucet will not swivel
if your faucet is new....the spout was put together wrong and it needs to be removed and re-attached correctly...(friction washer/ring in wrong position).....if not new....spray some penetrating oil on the connection that is supposed to swivel....make sure the surface is dry and try to avoid overspray. let it sit for 15 min...then spray it again...and again let it sit ....after sitting for a few minutes.....gently try to move the spout side to side...if no change...repeat the first processs...and continue to repeat until it becomes moveable....once moveable....detach the spout.....dry out and remove any foreign matter from the connection side on the faucet...then apply a small amount of faucet grease to the connection threads and the inside barrel....a thin even coat ...excess grease will clog your aerator...don't use too much....now repeat the cleaning and lubricating process on the removed spout connector....reassemble.....remove aerator....turn on the water and flush....replace the aerator....turn water on full blast....check for leaks and for swing...it should swivel now ....if not...loosen the connection nut a tad and try again....if still no swing....you are missing a friction ring somewhere in the connection and it needs to be replaced before you will be able to swing the spout.....good luck...
Oct 11, 2014 | Price Pfister Marielle Kitchen Faucet with...
How do you remove the spout cap (RP34090) from a 2 handle delta 2402 kitchen faucet? The spout cap is stuck.
If you are talking about the aerator at the end of the spout,take a pair of pliers and a rag put the rag on the aerator and turn counter clockwise(take care to make sure rag is covering all the area and that should help you get it off.If you plan on replaceing aerator which is about $6 just take the pliers and take it off.
Jun 10, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
I have a brand new moen muirfield high arc faucet with low pressure at spout but good pressure at side spray what can i do to get better pressure at spout
clevine336-
The design of a hand sprayer is meant to provide a higher pressure spray (the smaller outlet size means greater velocity in the water coming out of the sprayer head). That said, there could be something constricting the water flow in your faucet. If you unscrew the aerator on the end of the faucet do you get better pressure? Is the screen in the aerator clogged with sediment or mineral deposits? If this is the case you may have water requiring periodic cleaning of the aerator.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Moen Muirfield Kitchen Faucet with Side...
New faucet in December - water barely comes out of spout - sprayer works fine
Remove the areator see if water comes out spout better if so clean out aerator they get limed up or get junk in it..
Apr 03, 2011 | Delta Faucet Signature Single Handle...
Water just trickles out of tap
The problem most likely is a clogged aerator. That is the part that sticks out of the faucet that the water comes out of. You need to unscrew it, take it apart, and then remove any particles that are inside. Sometimes the easiest solution is to buy a new aerator at a hardware store. Take the old one in to make sure you get one that will fit.
Before replacing the aerator, run the faucet without it for a minute or so to clear out any remaining debris.
Unscrewing the aerator: Looking down on the faucet from above the sink, turn the aerator (which will be on the far side of the faucet) clockwise to remove it. You may have to grab it (carefully) with a pair of pliers. Close the drain before you do this so you don't loose any parts down the drain.
Jan 16, 2011 | Price Pfister Plumbing
Remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Jun 12, 2010 | Blanco 157-052-ST Grace Single Handle...
The pressure in my Delta faucet is suddenly low. The pressure throughout the rest of the house is fine. What is wrong? I replaced several pieces of the faucet but nothing worked.
Take the hoses off on the bottom of the faucet and blow air back through the faucet. Dirt can plug up the small openings right where the water enters the faucet. By the way I hope you checked the areator on the end of the spout, Dirt can plug that up also.
Nov 11, 2009 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
111 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
