Question about Crimestopper CoolStart(TM) 2-Way Remote Engine Starting System w/ LED LCD P
Reprogram keychain remote key chain fob - Crimestopper CoolStart(TM) 2-Way Remote Engine Starting System w/ LED LCD P
  • Edward Spraggins
    Edward Spraggins Dec 08, 2012
    my key chain remote stopped working so I need to program a new keyfob to the remote ignition in my car.
What does fob stand for
http://www.acronymfinder.com/FOB.html Possibly 'freight on board' If you are talking about a key fob then it is just any electronic device that can fit on a keychain like your car remote
Nov 27, 2013 | Cars & Trucks
The current key fob I have no longer does anything key less. I have to take the key out to unlock the doors and start the car. We bought an extra key fob off ebay when we got the car, now I can't find...
Did you try replacing the battery in the original key chain? There is a small watch battery inside that needs replacing from time to time. Your car manual will tell you how to use the keychain after changing the battery to it.
Feb 03, 2011 | 2008 Mazda Cx 9
Daewoo Reprogram Remote Key Fob how do you
I will see if you can do this without a scan tool.
Jan 11, 2011 | 2000 Daewoo Leganza
What does "KEY FOB BATTERY
Your keyless entry remote on your keychain needs a new battery..
Oct 27, 2010 | 2006 Pontiac G6
Hi! My name is Sharon and I have a 2009 Saturn Aura. Recently I have discovered that one of my key fobs works intermittently and on the spare, even after replacing the battery, does not lock/unlock the...
Hi, the key fob has contacts on a circuit board, much like a remote control for a tv, or a calculator. These contacts are what the buttons touch, to make it work. the buttons, or contacts may be dirty, with a carbon film on them causing the two buttons not to work, leaving only 1 functional. If you take it apart, much like putting a new battery in, you can actually pop out the green circuit board, and see the contacts. These can be cleaned with a pencil eraser. Try cleaning the contacts, and the back side of the buttons. A re program is not in order, because you have 1 function, and will either work as a whole, or none at all. If cleaning does not work, You may need a new fob. Good luck...coop442000
Sep 25, 2010 | 2009 Saturn Aura
Bulldog Deluxe500 in '02 trailblazer will not start or reset.
unplug all harnesses going to unit for 5 min plug all harnesses back in and reprogram remote, you do not need to program for voltage sense, that is the factory defalt or call tech support at 1-800-878-8007
Dec 16, 2009 | DLX 500 Remote Car Starter
Need new keychain alarm button
Is this a factory installed alarm system? If so, unlocking the driver door with the key will allow the car to start. If not then you will have to remove the aftermarket alarm system to start the car.
If you have a factory alarm system you can get a new FOB (key chain alarm button) from a ford dealer, but it must be programmed using a scanner , before it will work in your vehicle.
May 23, 2009 | 1996 Ford Explorer
It is possible to delete a lost 4 button remote key chain
Obtain the installation manual. You should be able to find this on Google. Search for Ge Simon 3 install manual. Follow te instructions for deleting sensors.
Jan 25, 2009 | GE Security Simon 3 Wireless Home Security...
Crimestopper CoolStart(TM) 2-Way Remote Engine Starting System w/ LED LCD P Logo
46 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
