Question about Sugden Audio Players & Recorders
SUGDEN CD-21 drawer wont open has CD inside. Stopped playing soon as I put in this CD was playing ok just before this. Can anyone help please.
This particular CD wouldnt play in car kept being spat out hense why I tried it indoors on the Sugden but drawer jammed soon as I tried to play!
  • 1,258 Answers
That is very strange. Is the disc warped or bent due to heat?
Posted on Dec 11, 2012
SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Posted on Oct 29, 2007
SOURCE: Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Posted on Mar 04, 2008
  • 31 Answers
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Posted on Sep 17, 2008
  • 35 Answers
SOURCE: cd spins buts doesn't play I fixed the drawer open closing
Clean the lens of the laser with a cotton swab. Remove the cover, and locate the glass lens at the top of the laser assembly. Pre-wet a cotton swab with glass cleaner and wipe the lens carefully without applying pressure. Use the other end of the swab to dry off and remove any residual dust or gunk.
Reassemble the unit and load a disc. If the problem was caused by dust or smog film on the lens, it should now play without any problem.
Posted on Mar 02, 2009
SOURCE: cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
Posted on May 18, 2009
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
Cant eject my disc
Dear! It is the fault about belt of a CD/ DVD Rom. You can remove this fault if you can change the belt that is inside the CD/ DVD Rom. And if you want to eject your disk as soon as possible? Use a pin and put inside the very small hole of CD/ DVD Rom and press under your controle slowly. Your disk will open.
Thank you.
Jul 26, 2009 | Sony PlayStation® 3 (80GB) Console
Will not play CD's ,press play and the drawer opens
darkie u need to clean your lazer i had seem problem with same model jake here
Dec 08, 2008 | Audio Players & Recorders
My 'the box super stopped working
you can only keep putting the new codes in they have stopped them updating themselves now codes are posted
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Jul 24, 2008 | Audio Players & Recorders
Fix
ok restart the cdmix1 it ll work..
Jun 23, 2008 | Nu Mark Numark (CD2CD) CD-RW Burner
TEAC CD P1120 wont play
hi there krell
you definetly have a fault in your cd players main board best solution take to electrical shop and ask them to test all the circuits it wont cost much to get them checked out and see how you go
hope this helps and if you have the time please rate me if you dont mind
thank you
fixya
Jan 10, 2008 | Teac CD-P1120 CD Player
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
127 people viewed this question
Top Sugden Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sugden Audio Player and Recorder Expert? Answer questions, earn points and help others
