Question about Acer Aspire Computers & Internet
Acer Predator screensaver is gone
After upgrading my windows7 premium to windows7 ultimate my screensaver has been deleted from my system. Where can I find a link to download this screensaver?
Makrin
  • 34 Answers
SOURCE: retsore acer
have you tried going into safe mode ?
To go into safe mode press f8 after the boot screen (one with computer/make logo)
after pressing f8 you should then get a menu
select safe mode with networking
then you can try activating it so that it removes the 30 day limit
or you can uninstall it
or the upgrade ultimate may just be a trial
is the key # somewhere in the package ?
Its usually under laptop (but thats probably the home premium #)
Alternatively
you can try using the upgrade ultimate or home premium disc and selecting repair/recover on the menu then select system restore and try restoring to an early point
Posted on Feb 23, 2008
SOURCE: bluetooth hardware removed
download the drivers for vista,
see tht the device is off and when prompted to switch on do so then
Posted on May 09, 2009
anmolsxn
  • 93 Answers
SOURCE: Hello Sir, I purchased Acer
The problem is with your Windows Boot file "bot.ini file" This file can become damage, corrupted or deleted for a number of reaons, (here seems the installation of Fedora 12) and id usually brought to your attention to by an error message befoe booting windows, the same message you are facing. there are two ways of removing it. 1-You can format your OS and re install it. or 2- repair your windows using the windows OS Cd.
Posted on Nov 15, 2010
bunnydawg
  • 5158 Answers
SOURCE: I want to upgrade bios
I would suggest updating the bios to the latest version which is f24a which can be found here (as well as the rest of the drivers) be VERY VERY sure that this is the exact machine you have as updating with the wrong bios will "brick" you computer. this should fix the issue you are having. if after updating the bios you still have problems, go to the laplink website and read the minimum requirements to run the program, especially the version of windows it normally runs on. then right click on the install program and choose troubleshoot compatability in the menu. when the wizard pops up choose the second choice option, troubleshoot compatability ... mark the first and third check boxes then click next... in that window choose the operating system it is normal run under. after you have done that and clicked next ... start the install by running the program. if after you have done that and the program works fine save the compatability settings and exit the wizard.
Posted on May 22, 2011
Joed911
  • 4338 Answers
SOURCE: acer aspire 9410-4317 running windows7
This link may help you:
http://acer.custhelp.com/app/answers/detail/a_id/2631
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Jun 28, 2011
I have an Acer predator G77600 running windows 7 it has been running fine until this morning I went to the PC and nothing was on the screen the pc was still turned on, I powered down and re booted but
When you turn on the power are there any sounds or lights coming? If not It sounds like a power supply problem, which is quite common. You need to get a tech to check its outputs. A replacement one is not too expensive and fairly simple to fit, but you need advice to get a quality one
Mar 28, 2014 | Acer Predator G7760 Desktop Pc Intel Core...
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
I need to upgrade my windows7 home basic to ultimate
First u need to buy license for ultimate version then through Upgrade advisor it will take few minutes to upgrade without any interfer with data
Aug 27, 2011 | Computers & Internet
I want my acer , from w7 starter to w7 ultimate
In Start / Programs you should be able to find "Windows Anytime Upgrade"
From that you will be able to upgrade from Starter to Ultimate.
More information can be found here:
http://windows.microsoft.com/en-GB/windows7/products/features/windows-anytime-upgrade
Thanks
May 05, 2011 | Computers & Internet
How can i upgrade freely from vista home basic to home premium
well u cannot Update ur Vista Basic to Premium freely.U need to Purchase the Vista Premium and then Upgrade on ur system.
May 22, 2009 | Microsoft Windows Vista Ultimate Edition
Sreensavers have dissapeared
hi my name is wesley. when you change to a different version of windows it will start most of your applications from fresh so you will have to manually put the screen savers you want use.
Jul 17, 2008 | Acer Aspireā„¢ T180 PC Desktop
Retsore acer
did you try to restore using alt+F10 ?
Feb 19, 2008 | Acer Aspire 5100 Notebook
Activating window vista ultimate
Can you provied me the information what you have upgraded?
Feb 13, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
