When on spin getting a lot of vibration and noise
Noise and vibration coming from back of drum
    New Friend:
Inspect the shock absorbers if noise is coming from the back during spin cycle
Posted on Dec 07, 2012
SOURCE: kenmore washer model 41740042990
there is a concrete block (a counter weight) inside the unit. maybe it fell off the bracket. remove back panel (after unplugging) and check it.
Posted on Feb 05, 2008
SearsTechToo
  • 261 Answers
SOURCE: drum out of balance
Hi Gerald, directly below the spring where it attaches to the basket suspension is a small hole, use a flash light to locate. If you get a chance, have you seen any dark metal shaving in the machine?
Posted on Sep 28, 2008
SOURCE: Noise on spin mode fast loud clanking like something in drum
Wow, we're having a similar problem vibrating like crazy...just online to try and figure it out..
Posted on Dec 29, 2008
the_admiral6
  • 14 Answers
SOURCE: Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Posted on Mar 07, 2009
  • 3 Answers
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
Posted on Aug 16, 2010
What is cause of loud vibration noise
In most cases, vibration sounds come from which ever helps the drum to spin with no resistance, In most cases those would be drum support wheels or bearings depending on the model.
In some rare cases, blower or belt pulley could also cause similar symptoms.
Feb 11, 2015 | Dryers
My washing machine spin drum started making lot of noise and started vibrating a lot.
Not sure why this has happened in a top loader but if its less than a month old call the shop you purchased from , they should still be liable for repair or replacement .any older call the manufacturer for repair.
Mar 08, 2012 | Washing Machines
While drying the drum makes suddenly a big noise and shakes a lot
Hi
Distribute the load of clothes when you put it in. Make sure they are balanced properly. If it's thumping during the spin cycle, stop it, open it up, move some clothes from the fuller side to the less full side, and see if that helps. Replace the springs inside the machine which suspend the washing drum. Open it up, take a look of it. Perhaps they're all saggy and this is permitting excessive vibration.
Put something under the machine to stop it from transmitting the vibrations to the floor of the house. An old sock folded several times and placed under each of the four feet may help. Rubber or foam will also work. Also, make certain the machine is level from front to back and side to side. Most washing machines have a large weight attached to the drum, usually a concrete block. It's supposed to prevent too much vibration. Check that one or more of the bolts holding it on haven't come loose.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Miele Novotronic Premier 500 Front Load...
Clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Dec 29, 2009 | GE WPXH214A Front Load Washer
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
Sounds like you have some sort of obstruction in the drum, and this is stopping it draining, thereby when it goes into spin the water is being forced out of the dispenser by centrifugal force.
Try turning the drum by hand, and if you feel a lot of resistance, then you have got something stuck in the drum.
Please rate this comment.
thanks.
Dec 10, 2008 | Tricity Bendix AW1000W Front Load Washer
Very hot at back, making humming noise, but drum isn't spinning.
the drive belt is likely broken
belt replacements for most models are simple and cheap
have no experience of bendix cannot give exact instructions
Nov 02, 2008 | Tricity Bendix TM310W Electric Dryer
Washer problems
Hi there!
The problem is probably the main drum bearing at the back.
Isolate power and water supplies.
The top will have to come off,(screws along top edge at back), then the motor mount slackened to remove the belt. Then try rotating the drum by hand, If the noise is still there, check for any items lodged between metal drum, and the outer plastic wash tub. If everything is clear, The noise will be from the rear bearing, which needs to be replaced.
I can assist you further with this.
Jun 19, 2008 | Zanussi ZWF1430W Front Load Washer
Knocking noise on spinning
it may cause more damage to other damper/suspension components if used. confirm exact fault- also check concrete weights for security.
Feb 16, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
