Question about Epson PowerLite 410W LCD Projector
Epson 460 powerlite hooked to smartboard green light blinking and no image.
The Epson 460 powerlite projector that is hooked up to smart board when powered up the power button continues to blink green and will not project anything. Is this the bulb? Not clear in manual what this means.
  • Jeff Farrington Dec 06, 2012
    Thank you. It does not go to a red light it just blinks green. Thats why I am noot sure it is the lamp/bulb?
  • gmontgome595
    gmontgome595 Dec 06, 2012
    I'm still betting on the lamp you can ook at it and see if it is blown or damaged.
    Champion:
  • Epson Expert
  • 225 Answers
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Posted on Dec 06, 2012
5 Suggested Answers
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
SOURCE: flashing red light
Hi ProjDoc, i have the same issue.... Can you tell me where I could order a Ballast, and how to replace it on my Epson projector?
Posted on Jan 07, 2010
SOURCE: One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
Posted on Dec 10, 2009
ViscamTech
  • 528 Answers
SOURCE: Epson PowerLite 410W projector (used
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Posted on Sep 23, 2011
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Blinking green power light on ux60 projector
I would refer to this page to determine if you ahve an internal problem or if your lamp is bad. Make sure you buy a lamp that has an original bulb inside and not a compatible. Original bulbs cost less than OEM but more than OEM-Compatible(knock off) but they last as long as OEM bulbs. Your SMART Hub Doesnt Turn your UX60 Projector On or Off 146535 SMART...
This link goes to a highly reputable company. They have the same Osram bulb as the OEM. SmartBoard Lamp
Mar 04, 2014 | Smartboard Smart Board 685ix, UX60...
Temperature light is on with no picture
Blinking red power and temp light is an internal failure for the projector. If under warranty the whole unit will be replaced.
Jan 11, 2013 | Epson PowerLite® 83c LCD Projector
Epson 84+ green light blinks no light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
May 21, 2012 | Epson Corporati PROJECTOR, EPSON,...
Epson PowerLite 410W LCD Projector Logo
683 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
