Question about Whirlpool Gh5184xps Microwave Oven gh5184xps / Gh5184xps
Locating reset button on my microwave - Whirlpool Gh5184xps Microwave Oven gh5184xps / Gh5184xps
    Top Expert:
  • 14,553 Answers
To my knowledge none have a reset button or circuit breaker. If the unit is total dead there will be (has to be) a fuse inside the unit.
Posted on Dec 06, 2012
How to locate the kenmore microwave 721.85033111 fuse?
You must open it up. There is no reset. If fuse is blown then check the door switches.
Aug 30, 2014 | Kenmore Microwave Ovens
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    No power to viking microwave unit.tripped fuse in house and than reset fuse but doesnt work.
    Check to see if you have a "reset" button on your microwave, or even just by pressing the "clear" button first. Check to see if you have a "master" or "red" reset or "test" button nearest to your microwave on a light switch and reset that if applicable. You could also check to see if your unit has a fuse and replace that. It's possible when you tripped the fuse in the house you might have blown the fuse in the microwave.
    Oct 09, 2010 | Viking DMOR205SS Microwave Oven
    Microwave has no power...is there a reset button?
    There is a fuse located on the circuit board inside the chassis; where the power cord enters the chassis
    Feb 11, 2010 | GE Microwave Ovens
    Sanyo microwave clock reset
    This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
    1. Unplug the unit for a minute then plug unit in.
    2. Press the clock (clock/timer) button once.
    3. Using the keypad, input the time you wish to set.
    4. Press the clock (clock/timer) button once.
    5. Press the stop/clear button, Time should remain.
    Hope this works, if not, let me know.
    Please take the time to give this solution a fix ya rating.
    clarkco
    Apr 12, 2009 | Sanyo Microwave Ovens
    Mw8115ssw no power
    There's no reset button, only a a hard reset. Unplug the unit for a minute or so. Then plug it back in and see if ti works.
    A microwave can be dead for many reasons.
    It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
    If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
    Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
    http://www.microwavedisplay.com/safety.txt
    http://www.microwavedisplay.com/disassembly.txt
    For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
    Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
    Jan 12, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
    No power on Jenn-Air JMC 7000 ADB Microwave
    I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
    My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
    Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
    I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
    Dec 18, 2007 | Jenn-Air JMC7000 Microwave Oven
    Whirlpool Gh5184xps Microwave Oven gh5184xps / Gh5184xps Logo
    567 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
