Question about Electrolux Central Vacuum
Poor suction from wall
The hose is clear but have tried all hose connections in each room and get no suction.
  • Kat Starkes Dec 09, 2012
    Repairman came out and determined that the seal on the cannister was missing so no suction..Last time it was emptied the part was discarded.
I have a model DC3 rainbow thar has lost suction. what can i do to fix it
Check suction at intake without any hose connected. If that is good, then connect hose and check suction again. If that is poor, then you have a clog. If still good, then check power nozzle by getting into the belt area.
RainVac
www.rainvac.com
800-523-0510
Apr 01, 2013 | Rainbow E series Canister Wet/Dry Vacuum
I installed the Hoover Wind Tunnel Central Vac in my new home. After connecting the wall outlets and successfully turning on the system from the hose control, I discovered there is lots of air flow t
I would recommend checking your wall outlets where the hose plugs in for any type of clog in the tubing. If the vacuum itself has great suction but when you go to the wall outlets that is probably something in the hose that is stuck. If cleared it will most likely have excellent suction throughout the entire system in the house.
Jul 21, 2012 | Vacuums
Very poor suction.No obstructions in hose.Just cleaned filter and emptied canister.
Are you getting good section at the wall inlet? If so, see below.
Check for a clog inside the power nozzle. Detach wands and drop a small coin into connection. It should fall through. If it doesn't, there's a clog that needs cleared.
A leaky hose could be the problem. Any vacuum hose is often mistreated, though intentionally. But due to the length of the CV hose, it undergoes quite a bit. Being constantly dragged around corners and pulled around, as well as improper storage can all result in holes/leaks in the hose. A few tiny holes throughout the length of the hose will result in an often dramatic loss of suction.
How old is the vacuum? It may be time to replace the hose.
Nov 22, 2010 | Electrolux Central Vacuum
I just bought a used Dyson DC07. Works good but
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction.
Poor suction can be caused by obstructions, poor air flow or a compomise in the air flow (hole in the hose). Since you have started with that I would next look at all filters and clean them. First check for suction at the motor, then at accessory hose and then the base. this will lead you to a suction issue. If your baelt has not been replaced in the last 6-12 mo I would change that too. check to make sure your carpet setting is coorect for the carpet being cleaned.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 15, 2009 | Vacuums
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 | Vacuums
Hoover Tempo Widepath 12 AMP, poor pick-up and suction. Fantastic suction at the attachment hose though.
Could be blockage in hose,, try straightening out the hose,,and shove a broom handle down there,,,,if there is no bend!! and clear the blockage out.
Jan 16, 2009 | Vacuums
Losing suction filter clean,hoses clear,output blower good,but very poor suction
if the blower is much stronger than the suction, you may have an air leakwhere the cover fits on tank or possibly a warped tank or cover. feel all around the unit for air being drawn in somewhere besides the hose. try it without the hose on and block the inlet for a couple seconds to see if the unit leaks air in. also replace the filter , dont try to clean it, the pores clog and reduce suction and damage motor.
Jun 11, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Picks up poorly
I'd check thoroughly, the hose right next to the bush roll.
Sep 13, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Vacuums Logo
105 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
