Question about Sony Walkman NWZ-W202 MP3 Player
Play button not working - Sony Walkman NWZ-W202 MP3 Player
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
Remote control power button and stop/play/home dont work
open the remote clean with petrol
or ony from dry cloth
thare was a corben in that key becouse that key are more useable so carben
Feb 19, 2010 | Philips DVDR 3355 DVD Recorder
Infinite play wireless controller turbo
I believe that it's a typo. You can only use turbo on one button at a time. Try it.
Press and hold the Turbo button, and press the button you want to use turbo with. If it doesn't work, your controller could be faulty and you may have to return it.
Nov 10, 2009 | Intec PlayStation 3 Infinite Play Wireless...
Play button won't work
replace the tact switch,but first check if pcb is cracked
Jul 29, 2009 | Televison & Video
DVD will not play when the play button is pushed
call support from manufacturer on how to reset your player,
For instance, on Samsung players after it is powered on you hold in both channel buttons for 10 sec and the player restarts. that fixed mine that had the same problem
Apr 11, 2009 | Toshiba SD-2109 DVD Player
USB guitar for 360 won't play correct notes
try the slots in the front, i never use the one on the back of the system to play games,
my rockband guitar works find in gh3
Dec 02, 2008 | Activision Guitar Hero III: Legends of...
Pause/Play Button problem
the same problem happened with my left control button. i couldnt turn back to the song. so i tried clicking the button several times turning the power on/off. eventually within about a week the button worked again. hope i helped in some way.
May 08, 2008 | Insignia NS-DA1G MP3 Player
Wheel and buttons not working
theres possibly some water in there, Id recommend takeing the ipod apart and drying very carefully so there is no water anywhere. you can use a hairdryer also.
but thats after you have the circuitboards and others apart, make sure you dont break anything while opening
http://www.youtube.com/watch?v=HRjLszFoNxU
dont get it too hot.
Apr 17, 2008 | Apple iPod nano
My play button wont work
The only thing I can think of is try new batteries. I know when mine plays and then shuts off by itself, the battery needs to be changed.
Hope it helps
Apr 01, 2008 | Coby MP-C883 MP3 Player
Sony Walkman NWZ-W202 MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
