Question about Startrac Fitness Products Exercise & Fitness
Error message E-2 on Lamar, Ignite #1726 and bike won't work
Everytime I plug it in I get error message and bike won't work
    Top Expert:
  • Startrac Fit... Master
  • 12,223 Answers
Please follow this steps and fix it. God bless you
    • 1 Check the connections on both ends of the data cable to ensure they are secure and connected properly. The data cable runs from the back of the console to the flywheel assembly. The covers over the flywheel assembly may need to be removed to access the data cable connection. Verify that there are no bent pins in the cable connection by detaching the connection and visually verifying all pins are straight. Reconnect the cable connections, ensuring that the small latch on the connectors snap into place.
    • 2 Verify that there are no cuts, crimps or other damage to the cable. If the cable is damaged, replace the cable with a new, undamaged cable.
    • 3 Replace the console if there are no problems with the cable or the connections.
Posted on Dec 07, 2012
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I just got a schwinn srb-1800 recumbent exercise
Follow this step
o
Open the battery cover from the back of the control screen and take out the batteries.
o 2
Use the screwdriver to take out the screws on the left side of the large plastic enclosure that encased the batteries. You can now bend the enclosure so that you can reach behind it to make the repairs.
o 3
Use the crescent wrench to unfasten the nut that holds the left pedal onto the crank.
o 4
Unfasten the mechanism that keeps the pedal on the crank with the allen wrench.
o 5
Unfasten the screws that keep the plastic side panel on the wheel. Use the stubby Phillips screwdriver to get these four screws off. You will have to bend the outer plastic enclosure to reach the screws; make sure you don't break it. Remove the plastic wheel side panel.
o 6
Put the batteries back in.
o 7
Find the cord that moves the magnetic plate at the base of the wheel. Manually pull the magnetic plate back from the wheel frame. Now that the plate is unstuck, the error message should disappear.
o 8
Replace all parts in the reverse order you took them apart.
Posted on Nov 15, 2011
Won't boot up. Error message "
did you try pluging into charger, my galaxy 2 if i run battery all the way down it wont do anything after it shuts down. at times i have had to plug in and wait sometimes 15-20 min before it will even flicker. hope it helps
Dec 31, 2012 | Cell Phones
Error code E-2 on Lamar, Ignite 1726 exercise bike
please follow this steps and fix it. God bless you
Dec 06, 2012 | Startrac Fitness Products Lamar L1400...
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
Oct 14, 2017 | LG Washing Machines
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Error code 40, found problem, still wont start
you can disconnect the battery to clear the codes. If I remember correctly the code 40 is indicating an open injector circuit. You might want to check that area as well as the service manual for more detail
Nov 15, 2011 | Yamaha YZF-R6 Motorcycles
I have a maytag Neptune washer mah6700aww. It stopped working and nothing works at all. It won't turn on so no error message can be read. Power still runs to the outlet and breaker is fine....
The part has only a 90 day warranty through Maytag (Whirlpool), so you have no warranty on it. If you have verified power, the control is faulty. I have posted a link to the part below for your convenience. As far as why it has failed again, there is no way to tell. I would recommend getting a surge protector to plug it in to.
Control Assembly
Kelly
May 25, 2011 | Maytag Washing Machines
Gaggia Digital Syncrony dredge drawer error won't
Hi
Do you still have the tab on the left side of the dredge drawer? If you do, you can loosen the 2 screw just above the slot wherer you put the credit card. Push down on the plastic ramp in the slot as far as you can, then holding the ramp down tighten the 2 screws. If you don't have the tab you will need a new dredge drawer. Also on some machines the drip tray will lift the dredge drawer and it will give this message. There is a extra piece of plastic in the 90 deg. notch that can be trimed out to stop it from lifting the dredge drawer.
May 14, 2011 | Gaggia Syncrony Compact Digital Espresso...
I need new biss key for ptv k feed
جناب پی ٹی وی ھوم کا نیا کوڈ چاھئے بہت ضروری ھے یہاں ھمارے گاوں میں کیبل ٹی وی کا پروگرام نہیں ھے ورلڈ کپ میچوں کو دیکھنا ھے اگر نیو کوڈ دیا جاییں تو بہت مہربانی ھوگی۔
zahir_star333@yahoo.com
mobile .03459518896
thanks**********
Mar 11, 2011 | Computers & Internet
Exercise & Fitness Logo
109 people viewed this question
Top Startrac Fitness Products Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Techmotionusa.com
Techmotionusa.com
Sportsmith LLC
Sportsmith LLC
Are you a Startrac Fitness Products Exercise and Fitnes Expert? Answer questions, earn points and help others
