Question about Wharfedale PowerCube PC-10 Subwoofer
Wharfdale sw 150 no sound
Red light on
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
Wharfedale sw150 amplifier circuit diagram
the wharfdale SW150 is a subwoofer (hence the SW for Sub Woofer) , not an amp
try again
Feb 25, 2015 | Audio Players & Recorders
Standby/timer light stays on red. no picture or sound on tv.
this is a simple capacitor fix at your local tv guy..should be 100 to $150 max
Apr 09, 2014 | Sony KP-48S75 48" Rear Projection...
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
I have a 1990 ford f 150 my brake lights and hazzards do not work. my tail lights and signal lights work.
circuit goes through brake switch, then to multifunction switch (turn signal sw) then to lights.
check brake swithc first.
Feb 03, 2010 | 1990 Ford F150
I just installed the unit, It gets station info, but no sound?
Hello! Check the vehicle's wiring to the new unit...
Ford wiring
Constant +12volts Green/Yellow.............+12volts with key off
Switched +12volts Yellow /black...............Ignition Sw.
Ground Red...............unusual but true
Illumination Blue/Red.................Radio lights
Send a comment.....I am here!...........saailer
Jan 22, 2010 | Pioneer GEX-P10HD HD Radio Tuner for Head...
Furnace keeps tripping off on limit switch. replaced limit switch still trips, blower motor seems to work fine.
It's always possible that the limit "dial" switch is sticking leading you to believe that it's only at 150º.
How old is the furnace and when was it last cleaned.
Dec 12, 2007 | Heating & Cooling
Getting playstation 3 sound coming out of dvd surround
This wont be very helpful, but, it is worth noting that although you may think you bought a "Wharfdale" product, i'm afraid you haven't. Chan bros. bought the rights to the name some time ago and so what you have is a cheap non-descript chinese import. sorry.
Oct 04, 2007 | Wharfedale DVD-M3 DVD Player
Wharfedale PowerCube PC-10 Subwoofer Logo
35 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
