Question about Kitchen Ranges
A fallen tree knocked out transformer/power to the house. When power restored, our Kitchen Aid Selectra stove's top burners worked, but the digital control display unit remained dark. the top burn
Digital control display is not functioning ("dark") Top range burners do work Am unable to operate any other functions of range other than top burners. When power returned to house, there was a loud "clank," and the oven door was/is locked.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 06, 2012
aborcass
  • 2651 Answers
SOURCE: kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Posted on Apr 03, 2008
  • 1073 Answers
SOURCE: oven burnout
replace the oven control
Posted on Apr 25, 2008
  • 22 Answers
SOURCE: frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Posted on Mar 31, 2009
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
Posted on Apr 07, 2009
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
Hi, I have a Selectra 30 and the panel has gone dark and the oven door is locked. If I unplug it and remove the back cover I can unlock the door manually. When I plug it back in the door locks again and...
First of all, why did you post a question about an oven under a dishwasher question? What is a Selectra 30? That is not the model number. The model number of the dishwasher in the subject does not help. Without knowing anything else, I would say you have a bad control board.
Dec 17, 2014 | KitchenAid Kitchen Aid Superba Series...
Problem with Kitchenaid Electric Range Stove Top Burner
there may be a loose connection in either the pipe or on the burner rings on the surface. Some stoves have a safety cutoff if gas supply is interrupted to avoid prolonged gas supply.
May 12, 2012 | KitchenAid KERA807P Electric Kitchen Range
Own a KitchenAid gas range superba, how do i clean the burner, one of my front burners the gas flow is very low, the stove has the glass/ceramic top with no wells & no way to get to the burners...only...
You'll need certified stove technician to service you kitchen Aid range. You have low gas flow on one of the burner. The manual gas control valve behind the knob needs to removed and cleaned. If you have one cleaned then have technician clear all four of these manual gas valves. While he cleaning the valve have do a complete check up of you Kitchen Aid range. Dangerous for the home owners to do this procedure because flowing natural gas or propane. In a lot the states you'll need to be certified by the state to work with natural gas, gas stove, ovens, gas home heating units, etc. It differentially a no,no here.
It is not the burners, it is gas flow valves for the burners. Most of the burner are made of aluminum and I wouldn't use any harsh cleaners of them. Check with Kitchen Aid and ask them what is recommend for cleaning the burners. Also the top of the range isn't ceramic but porcelain, it glass that has been melt to the top hood of the range. Don't use scratch pads, steel wool or any thing that will mare the Periclean surface of your stove.
If you can get the aluminum burner out to clean them then do so. GB you Allison and I wish you many year cooking on your Kitchen Aid range. stewbison
walk softly up on this earth and she will good to you...
Aug 21, 2011 | KitchenAid Kitchen Ranges
The self clean feature stops part way thro the cycle and knocks out the oven entirely. The gas stove top still works
Kitchen aid (now Whirlpool) has actually produced a defective stove here. Your problem is the thermostat in the rear of the unit. You can replace it yourself if you are handy, but that will not fix the problem that is built in to this very poor quality stove. If you ever try to use the self cleaning feature, it is most likely you will overheat the unit, and knock it out again and again.I wrote to Kitchen aid and received a very rude response from their "customer dis-service dept"...I told them theyir stove was defective and they wanted to sell me a NEW part for a high price, not even saying "sorry"...what a bad company! I urge all to stay away from Whirlpool products...they are junk!
May 22, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Burners abruptly stooped working on top of the stove
check electrical panel of your house and make sure both breakers are in the on possition ..
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
Stove top burners won't light.
Susan, there is no pilot flame on the Spectra models of ranges. However, the possibility that the electronic ignitors have gotten soaked and are shorting out is quite likely.
You should disconnect the power to the oven and remove the burner grates, burner caps, and the burner assembly cores to expose the ignitor posts. Check to see if there is any remaining water there and clean off and dry the ignitors and burners completely, as they might have something on them causing them to short out against the stove top, rather than spark properly, as they should.
Once you've cleaned and replaced the stove top parts, restore power and try to light each burner, one at a time. If none of them spark or light, then you need to check to make sure you haven't tripped a breaker for the stove or a GFCI outlet that the outlet that the stove might be plugged into, somewhere in the Kitchen.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
Low Flame is too high to simmer
there should be a regulator between the stove and the main gas line .unscrew lock nut turn valve clockwise to turn gas down. turn down too far , will turn gas off.
Jul 30, 2009 | Kitchen Ranges
Kitchen Ranges Logo
107 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
