Question about NEC PlasmaSync 42MP3 42 in. Television
Need stand feet 42"bush tv
I`m in need of foot plate, feet,pedlestal( not sure what to call it) as we no longer want our tv on the wall, i have been searching on line, can any one help please.
I might have one available...Mine..If I can't get my screen fixed....
Robbie
Posted on Jan 24, 2009
How many 2x3s are needed for ceiling 10'x11'
First of all we need to know is the two by threes inches or feet on your ceiling 10 x 11 ft you need to square it 10 times 11 divide whatever your two by threes are into the feet if their feet goes into feet you're okay if not you'll have to take change the two by threes two feet or the 10 x 11 to inches in that's reasonably simple if you know your math
Oct 27, 2017 | Computers & Internet
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
Tv when new was mounted on a wall now i want to put it back on the stand but have missed place it i need a new foot mount for it can i buy one
I would suggest that it will be not only easier but more satifying to visit your local harware store with one of the original feet and choose four new ones. No problem matching then so no odd feet!
Hope that does it for you.
Dec 15, 2010 | TruTech PLV1615T 15 in. LCD Television
42'' Sense LCD TV Removing the Stand
THE WAY I DO IT FOR ALL TV
usually you got 4 screw in the back of the tv need the bottom
be sure to put tv face down on your bed you gone have a surprise
gone fall from the stand
and pull it from the tv by the buttom
Mar 06, 2010 | Televison & Video
Yes,i switch on my tv and the picture and sound are perfect for 2 minutes ,then the screen goes blank.The power light comes on but no sound and no picture.please advise ,thanks
It is totally internal problem. May be chip set issue..i suggest you to go call service technician.Don't take a risk, just give it in safe hands for repairing.
Jul 22, 2009 | Philips 42PFL3603D 42 in. LCD TV
The screen goes complete blank with sound still on. It takes to shut TV off and power it on right away to get picture back-though the intervals getting shorter down the road . MY Screen goes black and I...
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Jun 01, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
NEC PlasmaSync 42MP3 42 in. Television Logo
105 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
