Question about Hoover Vacuums
WHERE CAN I FIND THE INSTRUCTION MANUAL FOR MLR HOOVER - DYN 7124 D - 1200RPM / A + AB/7KG
Where can i find the instruction manual for hoover washing machines?
  • 107 Answers
SOURCE: NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Posted on Dec 09, 2008
  • 3 Answers
SOURCE: We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Posted on Feb 11, 2009
CorvetteKing
  • 108 Answers
SOURCE: lost manual for hoover steam vac
You can find that manual on hoovers website (hoover.com) it is under customer service/parts.
Best of Luck
Posted on Jun 14, 2009
  • 430 Answers
SOURCE: Hoover steamvac lower hose replacement instruction
Try 1800 Customer service
Posted on Sep 06, 2009
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 10, 2010
Testimonial: "Excellent description! Thanks for the great solution and pictures to help!!!!"
I need to see instucktions for my hoover 3500 steam cleaner
Follow the link to view the instruction manual for the Hoover Steamvac... http://hoover.com/file/610/
Dec 12, 2015 | Hoover Vacuums
Hoover Aquamaster instructions, please? Link doesn't work. Thanks
Did you try hoover?
http://hoover.com/support/manuals/
If their link to the manual doesn't work, Just email them. They are pretty helpful. I hope this helps.
Nov 14, 2014 | Vacuums
LS 3500 instruction manual
Hi there! Follow the link to view the instruction manual for the Hoover Steamvac. http://hoover.com/file/610/
Hope this helps!
Sep 22, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I need a manual for hoover h 3000
Hi! Follow the link to view the instruction manual for the Hoover H3000. http://hoover.com/file/1703/
Hope this helps!
Jul 09, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
I need a replacement belt for Hoover Elite upright vaccum ,model no. U5043-930. What belt do I get?
Your vacuum cleaner originally came with Hoover belt part number 38528027, however Hoover has now discontinued this part number, and replaced this belt with the new belt which is part number 38528040.
The new belt is a little bit smaller then your old one, but unfortunately this is the only belt that Hoover currently makes that will fit your model.
Here's a direct link to our website if you still need to purchase one:
http://www.govacuum.com/agbelhoovpar7.html
I have also uploaded the parts diagram and instruction manual for you. The parts diagram gives you every single part number for all parts on your vacuum should ever need to know another part number. The owners manual will give you step by step instructions on how to change the belt, as well as other maintenance instructions.
Part Diagram for Hoover U5227-930:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/Part-diagram-hoover-u5043-930.pdf
Owners manual is actually for the commercial version of your vacuum, but this will be identical to your instruction manual which Hoover doesn't have available for free:
http://www.hoover.com/pdfs/manuals/C1414900.pdf
I hope that this information was helpful to you. If it was, please be so kind and rate my repair helpful by clicking the thumbs up icons in the top corner of the repair.
Chris J.
GoVacuum
Apr 04, 2010 | Hoover U5227-930 Elite Upright Vacuum
Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
May 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
53 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
