Question about Proscan 47LB45H 47 in. LCD TV
Color saturation the color is distorded and it look almost crome like
Color on tv is distorded
I need to know model and a photo of picture (you can post here) or a better description of the issue--for example;"Picture looks 3d but is not a 3d set" "colors are skewed"
Colors look like this photo
Dec 13, 2012 | Mitsubishi Televison & Video
My tv when it turns on there is no color and after a while the colors appears, also the picture is distorded, any sugestions?
Its a older set and I have fixed and even owned one---bad solder connections and or convergence problems---can you describe better what it looks like when cold?
Nov 04, 2012 | Televison & Video
How do i fix high saturation
Press the Func. button to diplay color modes in the little display.
When the display shows Color to the far left, you can switch color modes on the button below. STD is standard saturation, HIGH is high saturation, ORG. is less saturated that STD, and finally B/W
Jul 06, 2010 | Fuji FinePix S2 Pro Digital Camera
Four prong cord three prong outlet
Ok this is how you will wire the three prong to the dryer.
You have 2 wires that are gold/brass in color, those are the hot wires.
You have 1 wire that is crome/silver in color, that is the neutral
On back of fryer where you wire it you put the wires on like this right to left Gold/brass hot, silver/nuetral, then the other hot wire.
On back of dryer you will have screws from right to left this color gold/brass, silver/crome, then gold/brass again.
If you do have a 4 wire cord the extra wire is ground and you screw that to the machine body.
Mar 14, 2010 | Roper RGS7646KQ Gas Dryer
My ownerd manual will not download in this computer. How do I turn on the fine pix mode on the camera?
iam glad to be of help. The owners' manual can also be downloaded at the following internet address:
http://fujifilmusa.com/shared/bin/S1000fd_E.pdf
On page 79 of the manual the folllowing procedure for changing the finepix colour setting :
  • (STD) F-STANDARD: the contrast and color saturation are set to standard.use this mode for normal photography.
  • (C) F-CHROME: The contrast and color saturation are set to high.This mode is effective for taking more vivid shots of subjects such as flowers.
  • (B) F-B&W: This mode converts the colors in the photographed image to black and white
When setting the (C)F-CROME or (B) F-B&W the icon appears on the screen.
Hope this helps!
Oct 27, 2009 | Fuji FinePix S1000FD Digital Camera
Color lines on screen for super nintendo
You probably need a new AV cord. Sometimes they can get shorts in them.
Sep 28, 2009 | Nintendo Super NES Console
Color saturation
Could of been solved by buying a Canon.
Jun 03, 2009 | Nikon D90 Digital Camera with 18-105mm...
What is the Digital Effects Control (DEC)?
With this function, you can adjust exposure, contrast, and saturation through the viewfinder itself, prior to image capture. You can check how your adjustments will look using either the viewfinder or the LCD monitor. This feature makes it easy to get the unique images you want in many different shooting situations. DiMAGE 7i is capable of setting contrast, color saturation and filter in the following increments. Contrast: In seven levels from -3 to +3 Color Saturation: In seven levels from -3 to +3 Filter: In seven levels ranging from warm (reddish) to cool (bluish) colors.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Color Saturation
I have the same camera and felt the same way about the colors. You can adjust the saturation slightly in the camera settings by going to the menu then down to paramerters. I find that it doesnt change the saturation too much though. Also try playing around with the white balance. AWB is not always the best. If all else fails, shoot in RAW and use photoshop, that's what the pros do.
Sep 14, 2005 | Canon Digital Rebel XT / EOS 350D Body...
Proscan 47LB45H 47 in. LCD TV Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
