Question about Maytag Neptune MAH5500B Front Load Washer
Pre select cycle times are getting longer
Quich wash was 27 minutes now 42 minutes Standard cycle cold-cold was 47 minutes now 80 minutes. Example: When you push quick wash it now reads on the readout reads 42. Can the timer be going bad? Is the timer mechanical or digital? Is the timger getting longer because the machine is monotering something and remembering how long it took last time? Any Ideas? Thanks Roger
  • 164 Answers
Try cleaning the hose screens and the screens in the water valve. tuen off the water supply and remove the hoses from the back of the machine as well as the water supply. check for sediment or other debris and replace the screens as needed and reconnect.
Posted on Jun 16, 2007
Why does it take so long to wash cloths I have done everything 1 hour and half still washing
Hi Robin,
Many washers have different wash settings and rinses in addition to temperature options and water levels (or load size). The temperatures wont affect the wash times (but hot and warm water washes will cost you more for the expense of making the hot water), so choose whichever you think you need. The water level makes a small impact each time it needs to be filled (wash, rinse, etc.). A warm wash will fill in half the time as either a cold or hot wash - as both hot and cold water are combined to make a "warm" water cycle.
A "Normal" or "Regular" wash without a pre-soak or pre-wash cycle and a single rinse is usually sufficient for *most* laundry needs - especially if you're using dryer sheets. Otherwise, you may find fabric softener is not rinsed out enough to your liking (or not - it's a personal choice).
If your machine offers a "Max Extract" or longer spin setting - it is worth running it to reduce the amount of time they're in the expensive-to-use dryer.
If you need more help - provide your washer brand and model.
Oct 27, 2015 | Washing Machines
I have model #FGBD243KF1, Gallery 24" stainless. The wash cycle is taking almost 2 hours. Should it take this long? Also, when switching cycles during the wash time the motor whines a bit. Is this...
these units are pre programmed they can wash that longer and sometimes up to two hours and fourty five minutes. there are alot of factors involved.your unit sounds like it is running normally. at this time
Mar 27, 2011 | Frigidaire Dishwashers
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Whirlpool Dishwasher GU3600XTSB 3 - 4 hours to complete washing
Wash time is determined by the cycle you select, the incoming water temperature and the installation location. The new machines will heat the water to a predetermined temperature and it takes roughly 1 minute for each degree of rise, If the incoming water is at 120 deg and the wash cycle wants 165 than it will take 45 minutes just for that one cycle to complete, Factor in an outside wall with poor insulation or lower water temperature and it could take even longer. Eric
Dec 30, 2009 | Whirlpool GU3600XTS Dishwasher
What are the specs of my washer.cubic ft?
Amperage 15 or 20 amps Depth 31-1/2 in. Height 38 in. Width 27 in. Tub capacity 3.8 cu. ft. Number of cycles 8 Number of speeds 4 Number of temperature selections 3 Bleach dispenser yes Pre-wash/auto soak cycle yes Voltage 120 volts
Apr 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Waher fills and then quits, won't start the wash cycle
LAT7300AAW that is your model number AZ103872 FD that is your serial number
Jan 02, 2009 | Washing Machines
Wash cycles are increasing in time required to complete
cold water valve in back could be plugged causing longer fill times.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
362 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
