Question about Vivitar Cameras
What does MCDC on a vivitar camera mean without a memory card in it?
When I plug in my camera and turn on the power button it says MCDC on the screen. It won't do anything else. It won't even charge.
Fishi
  • 255 Answers
SOURCE: Camera won't turn on
Turn the camera off. Take out the card. Take out the battery. Put in the card. Put in the battery. Turn the camera on.
Posted on Sep 13, 2005
  • 102366 Answers
SOURCE: camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Posted on Apr 28, 2010
SOURCE: Vivitar 8010 camera wont turn on, but has power, red light is on.
I suspect you battery has died,this happened to me the other month.
Easily fixed by buying a new battery, got mine off Ebay £7.99
Posted on Jun 03, 2010
SOURCE: BATTERY DOES NOT CHARGE
battery does not hold charge
Posted on Mar 19, 2011
thenetguruz
  • 145 Answers
SOURCE: How do you get the
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
Posted on May 15, 2011
My sony camera dosn't work and i can't see anything just black screen
of course you need to check first, is it completely black screen. could be that its not even turning on.lucky if lets say beep feature was set to on . check if you press any buttons, is there any beeping sound. try to even press the playback and check if any icons will appear.or press the lcd button repeatedly and check if something will happen . if not , do power reset. take out the battery and hold the power button for 30sec. its like refreshing the memory of camera.. if still same thing. try changing batteries. camera also turns on by pressing playback button. if all ts fails, camera needs service. could be something wrong with its sensor.
Oct 24, 2012 | Sony Cyber-shot DSC-W50 Digital Camera
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
Apr 25, 2017 | Nikon CoolPix S4150
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
I purchases a vivitar vivicam 8025. Unfortunately the instructions got thrown away. I've only taken a few pics and the camera says "memory full insert sd memory card to transfer and take more...
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
The camera needs a memory card in order to save pictures. You can take pictures without one and view them on the screen, but those pictures are lost when you turn the camera off.
Jun 16, 2011 | Vivitar ViviCam 8025 Digital Camera
Cameras Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
