Question about Sharp Televison & Video
My tv keeps moving through input sources - Sharp Televison & Video
    Top Expert:
  • Sharp Master
  • 14,553 Answers
Most likely if the set has on it a physical button for this---the tiny switch under that button is bad---most common way to know is someone needs to get at the switch from inside the set and remove it.
Set will still function with the remote---if removing that part makes the set work, just leave it out and use the remote for that function.
Posted on Dec 06, 2012
Grandchildren put in video now cant get signal back on tv
On you remote control look for INPUT or SOURCE, cycle though until you get it back. Very often it will be listed as the name of the cable or satellite source.
Jul 04, 2016 | DISH Network Televison & Video
Others moved TV setting to AV-1 to watch DVD.I cannot get it return to TV mode.
input source !
On the remote control of the tv should be an input source button
press this and select DTV
Sep 19, 2015 | Televison & Video
How do I use the video source button? I can see the different video inputs I can select on the screen after hitting the button but I can't move the cursor to select a different video source an
On Most TVs I have messed with, Hit the input or source button muliple times to cycle throught the different inputs. Also make sure there is an active device on the input for the TV to recognize it. Good luck
Jan 03, 2015 | Televison & Video
Rca unusable signal
Your TV could be on the wrong input source. if your using red/white/yellow cables look for an inpout button or source or even TV/Video. your tV has many inputs on it and you can only acess them 1 at a time, this allows you to toggle through the input sources and when you get to the right on you'll have picture and sound
Sep 29, 2013 | RCA Televison & Video
I have a 6" plasma
Keep pushing the tv input button. This will allow you to cycle back through the other inputs and get you back to your source. When you pushed the button, you changed the source input.
Jul 09, 2011 | Televison & Video
My input source screen keeps popping up and scrolling through the options - once I select source (example TV) the TV will come on then the input source comes back on and keeps scrolling on its own
My new 4K Vizio 60" M60-C3 started scrolling through input channels on it's own and after a minute would stop and "land" on an input, then I would have to change it to the correct one. Then the volume started "racing" to 100 making it impossible to watch. Vizio repairman came and replaced a small board about 1.5 in. x 5 in. and it is back working again. It fell within the 1 year warranty, so no charge, and he suggested I go back to Wal-Mart where I bought it and spend $59 on the extended warranty. I am certainly going to try and do that.
Feb 11, 2011 | Insignia IS-LCDTV32 32 in. Television
T.v. flashes off and on while watching it but doesn't do it when watching dvd's
Dan,
I'm assuming that the source that flashes is sat/cab connection. If the cable types are the same between the dvd and the other source (both hdmi ?) then try swapping them. If not then purchase a cable to swap(keep the receipt and make sure you can return) to see if the problem goes away. If it is a cable/sat/dvr then try unplugging for about 30 minutes and plug back in. If that doesn't work, then try changing the input where the cable plugs into the tv . . . if its HDM1, then move it to HDM2 and make sure that you switch sources on the tv to new source . . .
The poodle guy
Nov 25, 2010 | Televison & Video
When i switch my tv on it turn's itself to standby, i can switch it back on again but it just keep's switching itself to stanby after a couple of minutes.
You need a live input source to the port that the TV is set to, or turn on the tv and switch input to a live input source, anything else and the tv shifts to standby.
Oct 13, 2010 | Televison & Video
I hit source button-no tv
You will have changed the inout signal on the Tv to either HDMI input or EXT1 , or AVI. You need to keep pressing the source button until you reach TV again, or...press the TV button (depending on what tv you have) :)
Mar 07, 2010 | Samsung TV Remote Control
Televison & Video Logo
19 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
