Question about Breville 800CPXL Juicer
The hinge pin in my 800CPXL jucer is stripped. Need a new pin.
I have a 800CPXL citris jucer and the upper handle hinge pin is stripped and will not tighten. I need a new pin.
    Genius:
  • 2,920 Answers
Can u put a small screw with a nut on the end of it to tighten it up? ive seen it done before and it works well
Posted on Jan 12, 2009
    Sergeant:
    Novelist:
  • 326 Answers
U can get the new pin at any local appliance shop as it is easily available for 5 dollars.
Where to buy filters to use in Olympic Jucer model 1000?
Wholistic Research company may be able to help, they sell juicers and are very knowledgeable
May 02, 2014 | Juicers
My juicer leaks under the spout. I can not figure out why. I have checked all the assembly and all the directions. It is only the second time I have used this. My machine is brand new. Any though
The spout, itself is hinged. It has two positions, an upper and a lower position. (Similar to a light switch). Make sure it is in it's lowest position when making juice, otherwise the liquid will collect in the inner bowl and leak out the sides of the juicer. Move the spout to the upper position to temporarily stop the flow of juice, such as when you change glasses or receptacles. Then, put the spout in the lower position to resume the flow of juice.
Dec 26, 2012 | Jack Lalanne Power Juicer 250 Watts
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
How do you get the latch arm back in. The bottom is easy but how do you snap the top????
Is this an older juicer and a new latch arm? Surprised you were able to snap it into the base.
If your problem is latching it down because it's a little too snug, file the upper tip a little to
increase the tolerance. Do it to a point where the latch arm will easily slip over the lip of the
cover and then latch it down.
Jan 11, 2011 | Omega 1000 Juice Extractor
The 6001 vabrated so much the top came off and the flang bent.
WARING AT 800 492 7464 HANDLES ACME
JUICERS. VIBRATION MAY NOT INDICATE
REPAIR. THIS JUICER DOES NOT EJECT
PULP SO IS PRONE TO VIBRATION JUST
LIKE AN INCORRECTLY LOADED WASHING
MACHINE. HOWEVER, SEVERE VIBRATION
WILL CAUSE THE BLADE TO CHEW UP THE
CHUTE. YOU WILL NEED A NEW COVER.
TALK TO WARING. ANOTHER PROBLEM
IS NEW COVER PROVIDED WILL NOT FIT
SOME OLDER JUICERS WITHOUT FILING
DOWN THE EDGE OF THE COVER. TAKES
TIME BUT CAN BE DONE.
Jun 24, 2009 | Acme 5001 Supreme Juicerator Juice...
User manual for Breville 800 class professional
Here is the the link to your juicer manual:
http://www.breville.ca/site/EN/products/800cpxl/800cpxl_manual.pdf
Take note that you need Adobe acrobat reader to open and print this document once downloaded. You can also download this for free from http://www.adobe.com if you don't already have it on your computer.
Best wishes,
Graemevm
May 22, 2009 | Breville BJE200XL 700 Watts Juicer
STRIPPING DOWN THE JUICER FOR CLEANING
Yes.  There should be an orange handle-looking accessory with to small metal rods sticking out that is made to clik into the wire mesh screen and unlock it be twisting the screen mechanism slightly so you can unscrew it out.
See the enclose photos of the tool.
Hope this helps...
-enov8
Mar 03, 2009 | Jack Lalanne Power Juicer (Stainless...
How to clean my jack lalanne power juicer
Take the top part of the juicer off so that just the shreder is visable. On top of the shreder are 2 small holes on either side of the blades. a handle devise with 2 pins came with the juicer. put the tool pins into the holes and twist counter clock wise. The blade will come off then rest is simple and the unit can be disassembled. If you have lost the tool disassembly will be more dificult but can still be accomplished using a cloth on top of the blades and twiting counter clock wise. Careful though or you will cut yourself
Jan 05, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Juicer
There is the metal thingy that slides up over the upper unit.  Pull it towards your firmly.  Once it's down you can lift off the top housing.  Then you'll see the blade.  You need that little orange crescent tool to fit into the two holes in the blade.  Turning it will loosen.  Then the blade screws off (righty tighty, lefty loosey).  It's just a matter of taking off the parts then and washing them.  The screen thingy is easiest to wash from the outside with a nice scubby pad.  Reassembles same way.
Sep 12, 2008 | Jack Lalanne Power Juicer 250 Watts
The blade will not spin when the top piece is secure, & I the inside will not come out to clean
There is a roll pin under the flywheel, I you can get the basket off then you pull up on the flywheel , It is the last part before the motor housing. Once you have that off I think you may find that pin is sheared off. It is a common automotive or bearing house part. push out the old and push in the new pin and away you go. The new pin shoud protrude about 3?16 " on both sides of the pin. I hope this helps.
Dec 27, 2006 | Acme 6001 Juice Extractor
Breville 800CPXL Juicer Logo
Top Breville Juicers Experts
Greg Cann
Greg Cann
just-ice
Colin Stickland
Colin Stickland
Are you a Breville Juicer Expert? Answer questions, earn points and help others
