Question about Proform 650 Crosstrainer Treadmill
My proform 545s keeps blowing fuse. worked a coupla of weeks first time I replaced it , now blows as soon as I turn it on
    Top Expert:
  • Proform Master
  • 12,223 Answers
1) Lube the deck belt use 100% silicones or wax, read your instruction manual
2) Lube the rollers bearing use wd-40
3) Replace fuse and see if is o.k now
4) If the problem persist you must test the tension for drive belt motor, and adjust it according.
5) Test the input voltage motor, see my personal TIPS for motor help and troubleshooting.
6) Use the treadmills directing from the source DO NOT USE any extension power cord!
7) Test again if the problem persist,now you have power supply or control board faulty. see the block diagram.attached.
God bless you
my proform 545s keeps blowing fuse. worked a coupl - 12_7_2012_4_03_10_pm.gif
Posted on Dec 07, 2012
3 Suggested Answers
  • 14 Answers
SOURCE: Proform 570 blowing fuse
there are generally two control boards, I am assuming you looked at the lower one. I would first disconnect the power leads at the board and see if it still blows the circuit breaker (fuse?). If it does the check wiring for short. If OK then reconnect power leads and then disconnect all other wires (plug-ins) to the board and try again, each time plug a connection in and retry. (remember to disconnect power each time). I have a feeling the smoke got let out of this lower board and may need replacement. hope this helps
www.twincityrepair.com
Posted on Mar 02, 2009
maxtreadmill
  • 832 Answers
SOURCE: Proform 545S needs replacement walking belt
Here is the replacement part page for iconfitness.com
www.iconservice.com/CustomerService/partsModelSearch.do
Posted on Apr 16, 2010
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
Ignition fuse switch keeps blowing
you have a short in that circuit chck your harness for wiring that might be exposed to ground or pinched
Apr 13, 2014 | 2006 Kia Sedona
The Wiper fuse keeps blowing? Any Ideas?
Does the fuse blow as soon as you turn on the switch? Or do the wipers operate for a bit then the fuse blows? Will the wipers work in intermittent mode? Can you move the wipers by hand? Unless other wiring work has been done (eg radio replaced) I suspect the wiper motor is toast.
Jun 25, 2012 | Chevrolet Cobalt Cars & Trucks
AM2, 15amp, Starter system, "ST" and "IGN" fuses...this fuse on my toyota 2000 corolla keeps blowing. battery is in good condition. Can you please help, as soon as I replace this fuse, and turn the...
Have an auto electrician look at it.
I had the same problem just last week. It turned out to be the idle regulator. Every time the IR got hot it would blow the fuse. You can drive the car without it attached but get it fixed asap. Got one for $40 from a spare parts place ($200 brand new) and my mechanic mate changed it for me (looked easy enough to do it yourself). Good luck.
Sep 04, 2010 | 2000 Toyota Corolla
Fuse Keeps Blowing
First off the reason for instant fuse blow is because this is a positive wire grounding out or touching/crossing a grounded surface. I would first target the Cig lighter outlet connections also if the outlet is rusty inside looking, replace it.
Jul 01, 2009 | 1994 Chevrolet K1500
Fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Jun 17, 2009 | Garden
No parking lights, fuse keeps blowing.
There is a ground not connected or a wire open that is causing it to blow
Mar 08, 2009 | 1999 Pontiac Montana
Mar 01, 2009 | Proform 575 Crosstrainer Treadmill
Proform 650 Crosstrainer Treadmill Logo
206 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
