Question about Wharfedale SW150 Subwoofer
No sound red light on
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
WONT TURN ON , GOES RED AMBER RED
Hmm, that sounds like the "red light of death".
These articles might be of use to you.
Red Flashing Light
PS3 Red Light Fix
Feb 23, 2010 | Sony Playstation 3 (PS3) Console
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
The audio light is red whether the sound is muted or not
1) Try updating your sound drivers, they probably control the light. It could be a hardware issue, and if the drivers don't work, there may not be any solution for you.
2) You should go into control panel and into your sound settings. There should be a number of devices listed. One of them is your HDMI output. You need to click on it and set it to the default sound output device. When you unplug your HDMI, you may need to do this again to get your regular computer speakers working.
Jun 22, 2009 | HP Pavilion dv7-1130us laptop
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Open Questions:
See all Wharfedale SW150 Subwoofer Questions
Wharfedale SW150 Subwoofer Logo
41 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
