Question about Brother P-Touch 1950 Label Printer
P touch 1950 how to turn off auto
Turn off auto settings
How do I update the Google play store app
  1. Turn the phone off, wait a bit, and turn it back on. Do this outside or near a window for best results.
  2. Check your phone Settings. Is Wi-Fi enabled? Is Data enabled? If you don't have at least one of these enabled, you won't receive updates. If you only have Wi-Fi enabled, you will only receive updates when you are connected to the internet via Wi-Fi.
  3. Check Apps in your phone Settings. Make sure the Google Play Store app is enabled.
  4. Check the settings within the App itself. You can set the app to update automatically.
  • Launch the Play Store app.
  • In the upper left corner, touch the three horizontal bars next to Google Play.
  • Touch Settings (near the bottom).
  • Touch Auto-update apps and select one of the choices. I have mine set to "Auto-update apps over Wi-Fi only."
If none of this works, contact your provider.
I hope this helps!
Mar 29, 2015 | Tablets & eReaders
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
I want to remove a number from the reject list on samsung genio touch please
go to menu> settings> application settings > call> all calls> auto reject. In this u can either turn off auto reject by setting activation to 'off', or unselect any nos u added by mistake to the reject list
Mar 04, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
I have an LG LMVH1750ST microwave convection oven. When I activate the fan for cooking purposes and then try to turn off, it does not respond. I have to pull electrical plug and reprogram for one minute....
From the owner's manual under OPERATION "VENT FAN":
"If the temperature from the range or cooktop below the oven gets too hot, the vent fan in the vent hood will automatically turn on at the 4-Speed setting to protect the oven. When this occurs, the VENT ON/OFF pad will not turn the fan off."
You should check your "vent fan auto time set" setting.
Here's one thing to try to set it to turn off after 10 minutes:
Touch the Vent ON/OFF pad, then touch the "5-SPEED VENT" pad until "level 4" appears in the display, then touch "AUTO TIME SET" the desired number of times.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | LG Microwave Ovens
Playing cod4, slow jerky poor performance
First of all I hope that you properly uninstalled the graphics drivers and restarted before you installed the graphics drivers for your new card. Old left over drivers can cause a major problem.
Assuming you did it right read below.
What graphics settings do you have it on? And is your firewall set to let it open?
You should also list your processor and the speed and make of your memmory.
I play cod4 on high with an agp .1950 pro @ 1024x768 resolution.
turn off antileasing and aniostropic filtering. Turn all optional settings off but keep textures on medium
No offense but you have the low end version of the hd 2xxx series and can probly only play at medium at best.
You can also go into catylst control panel and make sure the settings are auto balanced.
Jun 01, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
Labeler #1950
Press "Line Out" to remove return character, It thinks you want to print on more than one line so is making font smaller to fit. Good luck.
Jan 21, 2008 | Brother P-Touch 1180 Label Printer
Brother P-Touch 1950 Label Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
