I have an Hp pavilion ze 4800 and think that the battery is completely dead how can I tell for sure'
The little blue light that usually flashes on the front of the computer is not coming on at all and when it boots up, all I get is a black screen. The ac power cord works fine.
  • 7,627 Answers
Pull the AC plug. If it's more the 4 years, I would say it's done. A battery has a Cycle limit, charge/discharge. Be sure to shop for a quality battery, stay clear of cheap batterys, they often don't work well with your laptop. If you have a multimeter you can verify, but if it will not charge or hold a charge, it's most likely time to replace.
Posted on Dec 06, 2012
pontelemon
  • 531 Answers
SOURCE: laptop wont boot and the battery and power lights flash
"......no beeps and it is a 3rd party charger for this model of laptop."
That 3rd party adapter could be the problem. Also, try to take out the battery and power it up from AC adapter only.
Ideally, try to find original AC adapter just for testing.
Posted on Apr 16, 2009
SOURCE: black screen will not boot up
ok, hubby had this problem on his Compaq...black screen...seemed to be doing something as the cd drive would spin, all lights came on, but black screen. Don't know how long this will work, but try pressing the frame above the F6 key when you boot up. (I know it sounds weird, but work with me!)
There is something about this being where the video card attaches to the mother board and no clue how long it will continue to solve the problem. It will give you enough time to at least retrieve data you need off of your hard drive and burn to cd(s). I think the video card is integrated into the motherboard, thus once it dies completely, you'll still have all of your data backed up as it will be as expensive to replace the motherboard as it will to buy a new laptop!
Good luck! (We are furiously backing up data as I type!!!!)
Posted on Apr 19, 2009
  • 987 Answers
SOURCE: Toshiba laptop will not boot - black screen
The RAM might have problem...
Posted on Jun 06, 2009
efs_perpends
  • 1996 Answers
SOURCE: Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
  • 143 Answers
SOURCE: HP Pavilion dv2500 - FTB
The troubleshooting you have done seems to be fine. It does not seem to be a problem with the power supply,cord or battery.Did you try a hard reset. If there is a reset button on the bottom of your laptop, you might want to try pressing that with laptop plugged in, not plugged in, with battery, without battery and different combinations thereof.
If this does not work or you don't have a reset button read on.
Before assuming it's the motherboard, there is one other possibility. There is a part called a PCA switch. It is possible this switch has gone bad or a plug might have come loose.
If you are comfortable with doing your own work, you can obtain a repair manual for your laptop online. Within this manual, it should explain what is involved in replacing this part. It is really not too complicated.
It does not sound like a hard drive problem simply because it doesn't seem to be getting power to any other part of the laptop.
You can try these steps.
Regards
Posted on Aug 03, 2009
Remote starter doesn't work when pressed
I think that you answered it yourself. Give you 1 point. The continual is the processor searching but not finding its mate. Replace the battery and repair them.
May 11, 2017 | 5101 LE 1 Way Car Remote Starter System
Hp pavilion ze1210 intermittently boots up or will not turn on at all.
ok it's a laptop., old.
let me guess 2003 made, square 4:5 screen
XP removed, (smart idea) Linux installed.
I guess the screen is 100% dead, not one pixel ever glows, right?
no text, ,no BIOS screens on demand, (esc key pressed, power on)
1: step 1 is always remove the main big battery. run now?
2: try external VGA screen yet, to see if the old internal screen is dead? see that VGA jack on the rear, and the hot function key that turns it on, bingo.?
(use a flash light to see if screen internal has data but the
CCFL back lamp is dead.?)
4: if bios is dead and both screens fail,what is next.?
19vdc from the power pack must reach the guts (MOBO)
if not all HP lap tops die. use a voltmeter or get a spare power pack
many power packs this old are now bad. 14 years old,
the can be good, bad, or weak. weak is bad.
5: sparks is a bad thing, in all cases, when heard it needs service.
BSOD:
http://pcdied.com/#black-screens
May 04, 2017 | HP Pavilion ze1210 Notebook
My hp pavilion 734n wont power up
Open the case and ground yourself then:
1. Make sure all your expansion cards are seated well.
2. Make sure all your power plugs are ALL seated and seated well.
3. Make sure your RAM is seated well.
4. Make sure your front panel plugs are seated well and in the correct
spots.
(Basically make sure something above didn't come loose.)
5. Test the power supply or get it tested at a computer shop if none of
the above fixes it. Just because the green light comes on doesn't
mean it's not dead or dying.
6. Replace the CMOS Battery. (This is rare to stop a boot but it does
happen)
7. If none of the above reveals a solution then your motherboard is dead.
Good Luck!
May 17, 2012 | HP Computers & Internet
My hp pavilion dv6000 does not turn on power button just blinks and goes back off
For this problem, I'd check to see if are you getting the correct voltage out of your power adapter? It should be about 18v.
Try turning it on with the battery and without the battery.
If the computer has been working, it could be that the battery is dead and the DC jack that passes power from the adapter to the computer is loose. Try wiggling is a little and see if the power light comes on.
I think that the problem is you are not getting power to the system and this is why you get a brief flash and nothing else.
May 25, 2011 | HP Pavilion dv6000z Notebook
Have a Pavilion Desktop HP with upgrade from vista to windows 7 ultimate. Turned the power on and no blue light and no monitor yet the fans were running. Computer monitor said no input and went back to...
First I think you should do some troubleshooting. Try hooking up your computer to a different monitor and see if there's any display when you boot up. If that doesn't work, then open up the desktop and make sure all of the power connections are solid. One that sometimes comes off is the 2nd motherboard power connector. Because you aren't seeing the blue LED, I think it might be that connector. The motherboard has one 24 or 26 pin power connector and one simple 4 pin connector. The 4 pin is usually in a corner near the processor. Take a look at that to see if your motherboard is getting all of the power it needs. If everything is connected properly and your monitor isn't the problem, the new power supply you ordered could fix the problem. I hope this helps!
Apr 15, 2011 | HP Pavilion a6750f PC PC Desktop
Press on blue lights flash on then go off
Your battery is dead or your charger is dead or maybe both are dead.
Oct 25, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv9700t battery dead, faint blue flash from plug
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 18, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Hp Pavilion dv6000 Won't start
If you have'nt done any upgrades like windows or memory
I think you just need a new fan
possibly power supply
if you take it to a small pc shop they will test power and fan for you usually on the spot at little or no cost
please don't forget to rate me
Feb 04, 2009 | HP Pavilion dv6000z Notebook
Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
hp pavilion zv5000 battery Compatible with Code:
  • Compaq 346970-001
  • Compaq Hstnn-db02
  • Compaq Hstnn-ub02
  • Compaq pp2100
  • Compaq pp2200
  • Hp 346970-001
  • Hp Compaq Hstnn-ib04
  • Hp dp390a
  • Hp dp399a
  • Hp Hstnn-db02
  • Hp Hstnn-ub02
  • so it is campatible with it~~
  • Nov 21, 2007 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    Computers & Internet Logo
    David Payne
    David Payne
