Question about Nokia 2330 Cell Phone
My nokia 2330 won't turn on unless i remove the battery then it turns off again
It just started today. It's driving me nuts!
  • 4 Answers
SOURCE: Nokia N95 Wont start up properly
hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off.
• Remove the battery, SIM card and memory card for at least 15 minutes.
• Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*].
• Press the power button for 1 second.
• Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
Posted on Aug 03, 2009
SOURCE: Nokia 2330-c hangs
dear sir i have one problam thats is nokia 2330 automatic swich of in 1 min so i need your help plz help m e
Posted on May 02, 2010
Takasashi
  • 67 Answers
SOURCE: My Nokia E63 is not
Hi Amosfreekid,
Welcome to fixya. For your Nokia E63, try the ff solutions:
Repair hints on Nokia E63 Power ON-OFF failure problem.
1. Check the keypad flex matrix for possible damaged, replace if necessary.
2. Check and try to clean the keypad pin connector.
3. From the pin connector locate the resistor and the ESD protection diode., Trace down the power key line paths.
4. Check/replace the 47K resistor and the ESd diode.
5. The power key connection is connected directly to AVILMA. check and try to rework the power IC.
if these are all sounding greek to you, in a gist, these only means, check the chip underneath the keypad, especially the one under the power button, cause it may just be dirty.
Posted on Jul 05, 2011
rockmeister
  • 2047 Answers
SOURCE: my nokia n95 won't charge,
First check the charger by using it to charge a different phone to determine if the charger is functioning fine. After doing this check the battery is properly installed if both options above are in good condition then sorry to say but the central board on your unit is probably bad and will need replacement.
the central board is the main component of the phone and acts as thee brain of the device, all functions go through it. When you purchase a new battery the unit should at least come on even if the charging function does not work.
best refer it to an expert to determine if the entire board is spoilt or just the power segment of the board.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Jul 08, 2011
toto_bader
  • 32 Answers
SOURCE: Yesterday I turned off my
that problem passed with my friend..you may change your batterie and maybe it works...if it works plz rank this solution!
Posted on Sep 12, 2011
Can't remove centre wheel nut on Hyundai excel '99
You can if you have a 3 foot long 3/4" drive ratchet
or a 1/2" drive air impact tool
Mar 09, 2013 | Hyundai Excel Cars & Trucks
Seagate Freeagent goflex not detecting
It sounds like the drive is failing. So you will need data recovery services.
A remote service is http://FreeDataRecovery.us
Aug 29, 2012 | Seagate FreeAgent GoFLex 500GB...
I'm driving a 2000 Chrysler 300M. Had front brake pads & rotors changed 2 weeks ago. Front end has been noisy since & I suspect sticking calipers , as i was informed they did not get clean
The front calipers are not the problem...did a shop replace the pads and rotors? Or did a friend replace these parts. The Chrysler front pads and rotors are an excellent design...easy to service and replace parts...only 2 bolts hold on each caliper, and the rotor is held in place with the caliper, and wheel. My first thought was a front wheel bearing is grinding, but you should have noticed this before the brake parts change. The pads could be installed backwards also...my second thought was you may have a loose wheel or two...retighten all 5 lug nuts by using the "star" tightening method, you may be surprised that the loose lug nuts are the only problem. Hope this helps.
Jul 12, 2012 | 2000 Chrysler 300M
Replacing 5007 baseplate
I hope we're talking about the same nut, is it the one on the lever to lock the cutting depth? If so, it's held in place by a lock plate that you remove by taking out the small pan head screw next to the nut. After you take the lock plate off the nut should come off easily.
May 22, 2012 | Makita 7 1/4" Circular Saw 5007NB
Duramax won't start!
just had this problem it was the PDM ended up replacing the glow plugs
best price and life time warranty for both was at Auto Zone recommend if you buy the PDM get the extension cable and move the PDM to a cooler location
Apr 30, 2012 | 2005 GMC Sierra 2500HD 4WD
Why is my tile saw making different noises?
Sounds like you have bearings going/gone bad. If it's a direct drive model, check the bearings in the motor and on the arbor. If it's a belt driven model check the bearings on either end of the arbor shaft. As bearings go bad, someone using the saw regularly will notice a different tone in the tool. If you are getting vibrations that bad, the bearings are already loosing balls or the race is tore up and all the balls are on one side and can't doing their job correctly.
Mar 10, 2012 | Ridgid Saws
I had the car in storage for 35 days. Upon startup, battery was dead. I took the dead battery out(only 1 year old) and put in a good battery which started the car, while the car was running good I took out...
You recycle the old dead battery
Have no idea why you even put that back in
Common sense & your friend is correct
You don't disconnect anything on today's
vehicles, even with the key on
Put in a new battery,start the car, warm it up
& drive it for awhile & maybe you will get lucky
& it will complete some of the drive cycles & run some
monitors ,you know nothing about & it will be fine
If not, your mechanic friend should be about to stop
by with the bosses scan tool & help you out
Sep 23, 2011 | 1999 Acura TL
93 Dynasty 3.3, driving today and the air bag light was staying on then I noticed my windows would not roll down nor would the heater fan run then the car overheated. I had replaced the cooling fan relay...
With a car that old & that many problems,
I would get rid of it
It needs too much work & I don't sense that
is your area of expertise
When you start becoming a butcher & wiring things,
instead of repairing them properly,it is time to quit
& get something else
Jul 06, 2011 | 1993 Dodge Dynasty
'04 Kymco Venox won't start. Bought it a few months ago from someone w. about 20,000 miles on it. Always runs good/never had a problem w. it 'til yesterday. Ran outta gas on the road...put more...
Hi Mrcherry99, for this situation I would call my local dealer or reputable shop's service department and inquire about any possible quick fix. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if possible, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
May 18, 2011 | 2005 Kymco Venox 250
Nokia 2330 Cell Phone Logo
139 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
