Question about Bernina Activa 140
430 will not recognize wembroidery unit.
My 430 refuses to recognize the embroidery module. I had to stop in the middle of an embroidery project and I cannot get it to start again.
  • Anonymous Apr 27, 2009
    I had the same problem. Did you get it solved? I read somewhere that too much stabilizer will cause the machine to do this. I had been padding the edges of my hoop with folded paper towel when this happened. I removed and it seems to be working now...
I am the person who posted the solution about too much stabilizer. Unfortunately that did not solve the problem in the long term. I spoke with the Bernina dealer and found out that the sewing machine needed to be recalibrated. I found out how to do this from my user manual and the problem appears to be solved for now... hope that works for you
Posted on Apr 29, 2009
My Bernini 830 would not recognize the embroidery attachment. I re-attached many times, but it doesn't work.
I assume you mean a Bernina 830. If you have removed the slide-on table, I have two possible solutions. I've seen this with a couple of Viking embroidery attachment units. (I am also assuming it's not a hoop issue.)
You could have corrosion on the pins that send the signals between the embroidery attachment and the sewing machine. Remove the embroidery attachment and turn off the sewing machine. Unplug the sewing machine. Spray the pins with an electronic contact cleaner; one example is here: http://www.homedepot.com/p/CRC-QD-11-oz-Contact-Cleaner-02130-6/202262505 . Push the embroidery attachment into the sewing machine by lifting up the far side and then sliding it into the port. Remove the embroidery attachment. Repeat this a few times. (The friction of the insertion and removal will remove any dirt or corrosion.) Plug in the sewing machine and turn it on. Try connecting the embroidery attachment. If it works, remember to clean the contacts the next time the embroidery attachment isn't recognized.
Once I helped someone with two sewing/embroidery machines with an unrecognized embroidery attachment. In that case, the person swapped which embroidery unit went with which machine. The contacts were not the same and didn't mate. Once the correct machine and embroidery unit were paired, the embroidery unit was recognized instantly.
I hope this helps. If it doesn't, you may need to talk to your Bernina repair technician at your local shop.
Aug 19, 2017 | Sewing Machines
When the embroidery unit is on the machine the "the feed dogs are raised lower them" comes on when I go to the embroidery edit or embroidery on my lcd screen and the feed dogs are down.
The problem you've explained isn't totally clear. I'll try to give help on your problem.
On embroidery machines the feed dogs are suppose to be down while operating in the embroidery mode.
When you change programs to embroidery the sewing machine recognizes this mode and automatically makes the feed dogs go into the down position.
If you are attempting to operate embroidery and your feed dogs don't go under the plate then: Try the switch that is under the storage unit and switch it to free arm.
Aug 25, 2015 | Sewing Machines
Do feed dogs drop automatically on SE-400 when embroidery unit is attached?
Yes they should unless the tab on the middle of the embroidery unit is broken.
Jul 31, 2014 | Brother SE-400 Sewing & Embroidery Machine
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
I have a Brother Ult 2001 and I was right in the middle of monogramming a towel using the large frame when I ran out of bobbin. I took the frame out and changed the bobbin and when I returned the frame to...
My friend just had this problem a couple weeks ago. Here's what we did. We cleaned the bobbin case with canned air lightly. We turned the machine off and disconnected the embroidery unit. Turned the machine on without the embroidery unit and ran a straight stitch. Then we turned it off, reattached the embroidery unit and touched another design of a different size. Attached the hoop without fabric just to see if it would "take it" and it did so we put the right size hoop back on and selected the design we were on originally and it worked. Some times these machines are just "touchy" and don't let you do something and after a "rest" they're ok. I hope this works for you.
Aug 24, 2010 | Brother Sewing Machines
Using a bernina gold latch bobbin case on the Bernina 435 machine
There isn't a Bernina 435. If you are referring to the 430 than the gold latch bobbin case will not work in that machine. If you are talking about the Bernina 450 the gold latch will work in that machine, with or without the embroidery module.
Apr 06, 2009 | Bernina Sewing Machines
Bernina 180E Embroidery module not recognized
Anytime there is a communication issue between machine and module attach the module to a different machine and check it. Possibly at a dealership. This will tell you whether its the machine or module. If its the machine then the soldering points on the embroidery module plug to the A-print (on the side of the machine) circuitboard need to be checked. Then most likely replace the A-print circuitboard.
There are other tests that need to be done in the service program that will help pinpoint and troubleshoot issues with the embroidery unit. Such sensors or stepping motors, etc. Should be left to a tech.
Hope I helped.
Jan 25, 2009 | Bernina Artista 180
Bernina Aurora 430
I figured out the solution for this issue. It all has to do with the threading. And I mean literally follow the instructions word for word. Most importantly is the Bobbin thread. make sure to thread the bobbin through the case eyelet.
Jan 11, 2008 | Sewing Machines
Sewing Machines Logo
143 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
