Question about Compaq Presario Notebook
Okay my compaq presario f700 keeps turning its self off if its in high performence and its really annoying because when its on power saver it is slow. do you know what is wrong with it ,if so can you get back too me.
  • sebsadmom Jan 29, 2009
    It's only shut off on me once so far, but has been running really warm for the last day or 2. I had IE open and yahoo messager, and suddenly no power, it was dead. I was thinking this may have something to do with the temp of the unit itself the last couple of days, anyone have any ideas?
    Problem Solver:
  • 5 Answers
The question is a little vague, but if its running under stress and is shutting down, then its likely to be overheating and the unit is protecting itself.
Get a can of compressed air (or a vacuum cleaner, if you dont want to cough up) and clean the heatsink and fan ports.
If its not this, and you mean it keeps going into standby, either switch this off in Windows (Start -- Control Panel -- Power options) or go into your Bios and see if there is an option in their.
You can also usually switch off the 'CPU stepping' and leave it on full speed all the time (battery life will suffer).
Posted on Jan 12, 2009
MY COMPAQ PRESARIO TURN OFF WITH A BLACK SCREEN WEN IT WAS NEARLY COMPLETTING DOING FACTORY RESTORE
If you can get it to boot change the power settings to high performance, sleep and hibernate to never and the screen saver to never.
Jan 18, 2013 | HP Compaq Presario CQ40-330TU
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
How do i reset my computer to factory settings. its a compaq presario f700
Hi!
To restore your Compaq Presario PC f700: Turn the computer on, then while restarting, Press and hold the F11 key. Under HP Recovery Manager, select the option to perform a system recovery. ***Note*** Doing this will delete everything that are save in your computer. Back up your files before doing this.
Hope this can help.
Jul 24, 2011 | Compaq Presario Notebook
Compact presario f700 laptop will not turn on. It
Was there any power outage in your area and was the laptop plugged in at that time, if so your Motherboard has been fried, your need a new Motherboard.
Jul 19, 2010 | HP Compaq Presario F500 F700 and G6000...
Tell me which motherboard is in my compaq presario f700
Download PC Wizzard, ( it is free) Install, Here you will find all the info you need involving, Hardware performance, hardware specs, Good luck. I did do a search and found that the f700 has a Mobile AMD Sempron™ Processor 3600+ but no seprate mention on motherboard.
Sep 06, 2009 | HP Compaq Presario F500 F700 and G6000...
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
Compaq F700 Battery live very less
Giri,
Its normal, generally it comes with 80-90 min. You can use HP Power management to optimize the use of battery. Making screen less bright will increase the power backup.
Thanks
Iqbal
Apr 28, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario Notebook Logo
126 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
