Question about Apple iPod nano
Get no response at all from ipod8gb
Done charged tried ressetting same result notthing
  • Apple Master
  • 13,433 Answers
Hey,
sounds bad,
start with this page http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
in the end theres the warranty checking page.
if noting helps on the page use the last option - warranty assistant to check your warranty and get repairs.
Thanks,
Ekse
Posted on Feb 16, 2009
When i switch my key on, there is no electrical response, no lights,no ignition.
Don't have a clue,that doesn't say much or
do much, on your part
Do you have a repair shop you got to,
hopefully, several times a year?
No one can guess at your problems
If you had done some testing & provided
results & need guidance, then maybe someone
could suggest your next step,but you just need the
knowledge to work on any product
Nov 03, 2014 | Cars & Trucks
IPOD8GB WILL NOT COME ON/CHARGE
Connect the Ipod to the PC and if this is not detected then test on another PC before we can confirm that the ipod has errors within and must be referred. If not the memory must be scanned, remove files if they are corrupt , reload only if the ipod after reset switches on to work.
Dec 06, 2011 | Apple 20gb Ipod Mp3 Player With Click...
My Nokia E52 won't charge. When plugging in my charger, I either get a message "not charging" or it will charge for a few seconds and then stop.
This problem can be traced to only a few causes. Listed below are the causes and possible solutions to this problem.
1. It is most likely that your battery may not be having proper contact with the terminal that does the main work for charging it. The three terminals that can be seen perform different tasks and as such, when that which is responsible for drawing power from the battery to operate the phone is in good contact, the phone might work normally but refuse to charge when that which is responsible for charging the battery is not properly in place. The easiest way to solve this problem is to turn off your phone and remove the battery. Try to clean the battery and all of the phone's terminals without using any liquid and then re-insert the battery.
2. Your phone may be having a faulty charging port and as a result cannot perform the complete task of charging the battery. In this case, the only thing that can be done is to try to dust the charging port and try to charge again. If this actually happens to be the exact problem, you might have to take the phone to a repairer so as to open up the phone and do a proper scan through on the phone.
3. lastly and most unlikely, the battery may have been damaged and needs replacement. This also depends on how long the battery has been in use. If it has been in use for more than 3 years, it is advised you replace the battery. Also, you can try connecting the phone to another power source to see if that helps too.
Hope this solution was helpful?
May 24, 2011 | Nokia E52 Smartphone
My husband HTC hero turned itself off and won't come back on we have charged it and took the battery out still notthing. Please help
Try different chargers if you can, if that doesnt seem to work then you may need to test the battery. A common issue with a phone older than a year is that the charging port will go out through wear and tear. If this is what happened to your husband's hero you may need to take it to a service/repair center from your service provider. The fix is usually about 40$ and will in most cases take only a day.
Mar 06, 2011 | HTC Hero Smartphone
Ok, welmy phone won't charge at all, and it keeps
charging is hardware fault and for messaging resset the phone settings
May 21, 2010 | Motorola Mobility RAZR V3m Cellular Phone
I want to charge and download to my ipod8gb. I
Go to the apple website and download itunes at www.apple.com/itunes you will be able to use this to download your new software and tunes, Hope this helps.
Oct 31, 2009 | Apple iPod touch
Apple iPod nano Logo
50 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
