Question about Acer Aspire One AO532H-2527 Netbook
What is the the size of back bolts on the started for2002impala
I am having problem with the size of the back bolt of the starter
  • Acer Master
  • 7,627 Answers
Wrong category
Posted on Dec 06, 2012
Starter Bolt Size
you can buy them at autozone,they may even know what size you need. usually starter bolts are the same size and in some cases just the length is different. simply try the one you have in the other hole and if it works then problem solved on the size but the length may still be different.
Aug 12, 2012 | 1993 Dodge Dakota
What size bolts on a starter and is there three bolts on a starter
most starters have two bolts - a short one and a long one. if you take out the old starter, you should reuse the old bolts.
Dec 30, 2010 | Ford F-150 Cars & Trucks
How to change starter on 1994 corolla
The sizes given are the wrench sizes needed to perform the step.
1. Remove the negative battery cable from the battery.
2. Remove the hose that connects the air cleaner to the throttle body.
3. Remove the top of the air cleaner box (4 clips on the corners).
4. Take out the air filter. Disconnect the sensor on the side of the air cleaner.
5. Remove the three bolts (2 - 12mm, 1 - 10mm) that hold the bottom of the air cleaner box to the inner fender and remove the box.
6. Disconnect the two rubber hoses on the top of the air canister (one large, one small).
7. Loosen the clamp bolt (10mm) (be careful as there is a non-captive nut that will drop if you remove the bolt completely) and slide the air canister out.
8. Remove the two bolts that hold the fuel filter on to its bracket (10mm). It is the same bracket as the air canister's.
9. Remove the air canister/fuel filter bracket by removing the four bolts that hold it in place (10mm).
10. Remove the wire harness/hose bracket directly in front of the top starter bolt (12mm) - this will facilitate your ability to get a socket wrench on the starter bolt. On my car it was RIGHT in the way!
11. Loosen the top starter bolt (14mm).
12. Loosen the bottom starter bolt (14mm) and remove it completely.
13. Hold the starter up and remove the top bolt completely. Flip the starter over and place it on the drive axle below with the wiring facing up.
14. Disconnect the solenoid plug and the starter cable (12mm).
15. Remove the starter by snaking it through the driver's side of the motor compartment. There's enough room if you're patient - be careful not to snag anything and damage it.
16. Snake the new starter down through the driver's side reverse of the way the old one came out. Lie it on the drive axle and connect the solenoid connector and the cable.
17. Flip it over and up into place. Hold it in place and start the top bolt. Tighten it by hand enough that the starter stays in place by itself.
18. Start the bottom bolt; tighten it up all the way.
19. Tighten the top bolt the rest of the way.
20. Connect the battery cable and try the starter - before you put everything back!
21. Replace canister/fuel filter bracket and bolt the fuel filter in place.
22. Slide the air canister in and tighten the clamp bolt. Connect the two rubber hoses on top of it.
23. Install the bottom of the air cleaner box; plug in the sensor.
24. Put in the air filter and then replace the top of the air cleaner.
25. Connect the big hose from the air cleaner to the throttle body.
NOTE: You may have to reset the "check engine" light when you're finished (I think starting the car when we check it in Step 20 can freak out the computer since there are still things disconnected). To do this, find the fuse block on the driver's side of the engine compartment; remove the 15A EFI fuse for 30 seconds. Put the fuse back in - the light should now be reset.
That's it! Shouldn't need another one for another 150,000 miles!
A helpful rating and an testimonial would be greatly appreciated if you are satisfied with my solution ...
Oct 03, 2010 | 1994 Toyota Corolla
Replaced starter in 99 cadillac escalade. One of the mounting screws is missing, I need to purchase a new one. WHAT SIZE do I need, dont want to take the starter out again just to have a screw size, but I...
no doubt the bolts are all the same. take a bolt back out and take that bolt to a parts store and they will sell you a match. or wait and go to a dealer.
Oct 03, 2010 | 1999 Cadillac Escalade
Removeing the bolt from the crank pully
right put the starter motor back in,then re connect .put the right size socket on the pulley bolt and use a long snap on bar jammed into the suspension then crank the engine with the starter motor and it will undo itself ,dont forget to put some contact sdhesive back on the pulley bolt thread when rebuilding
Apr 12, 2010 | 1997 Volkswagen Jetta
Replacing started/ how many bolts hold in on?
starter has two bolts. make sure you are using self locking washers. you could also use thread tape or buy a tube of locktite. bolts are about 4-5 inches
Mar 31, 2009 | 1992 Pontiac Grand Am
What bolt to use for the bellhouseing on tranny?
most bolts for your bell housing are two inchs in lingth and are mittrck or mm. but what tipe of moter do you have i need the size and what tipe of tran's, do you have''''is it a v8''' or a 4-banger or a 6--''''' or a v--6'' my name is james'' you can e-mail me back at '' jay_win2002@yahoo.com'''
Jan 30, 2009 | 1983 Ford Mustang Hatchback
Acer Aspire One AO532H-2527 Netbook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
