Question about Electronics - Others
I have Iomega LDHD250-U external enclosure and lost the dc in cord and I need to know how to obtain another
  • Anonymous Mar 25, 2009
    I'm also unable to find replacement for power supply. I found some simular power supplys at La Cie but not sure if they would work.
  • Anonymous Apr 20, 2009
    Where to find a new power supply for thies HD ?
5 Suggested Answers
SOURCE: iomega external cdrom burner
I need to know what power cord comes with it
Posted on Jan 01, 2008
  • 9 Answers
SOURCE: can I use the Iomega LDHD250-u Hard drive with a mac?
Yes, absolutely, my only recommendation is that you use the Disk Utility to format it, so it's 100% compatible
Posted on Feb 14, 2009
bronk50
  • 27725 Answers
SOURCE: How do I erase all data data on my iomega ldhd250-u
click start click on my computer you should see your iomega drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your iomega drive select format
hope this helps
Posted on Jul 09, 2012
avergason
SOURCE: I lost the power cord to my external hard drive.
pdhd75ouse-72 first d might be an o.
I have the same issue as above
Posted on Jun 30, 2015
Poweer cord
Buy a new enclosure. You won't find a replacement for what you have.
Mar 13, 2014 | Verbatim SmartDisk USB1TB 1 Terabyte 1TB...
hope this helps
Jul 08, 2012 | Iomega (33215) 250 GB Hard Drive
Trying to find the operators manual for prestige desktop hard drive super speed usb 3.0 ,2 tb
The general directions is to plug the USB cable from the IOmega Prestige into any available (Open) USB port.
To open, (Access) the contents on the harddrive, double-click on the drive letter that corresponds with the IOmega.
In WinXP left-click on Start, then on My Computer.
In Win Vista and Win7 left-click on the Windows logo button, then on Computer.
You will see there are different drive letters;
Drive A: is reserved for a Floppy Drive. Older computers
Drive C: is for the Harddrive. (Hard Disk)
Drive D: is reserved for a recovery drive, or an optical drive (CD/DVD drive)
Drive E: is reserved for an optical drive, usually.
Drive letters beyond these are usually under the heading, Devices with Removable Storage
One of these drive letters should correspond with the IOmega.
Suggest, IOmega not plugged in, go to My Computer, or Computer, and look at the devices connected to the various drive letters.
Now plug the IOmega in, and see if it shows up next to a drive letter.
(Give the computer BIOS a few seconds)
Where there was NO device shown BEFORE, there should now be a device shown.
{No device shown before, but now there is. May not state IOmega, just external storage, or similar}
DOUBLE-click on the device shown.
For example:
I have drive letters C: D: E: F: G: H: I: J: and K:
Drive letter C: is for my harddrive.
Drive letter D: is for a recovery drive. (Partition in harddrive reserved for recovery)
Drive letter E: is for an optical drive (CD/DVD drive)
Drive letters F through K are reserved for an external storage device.
Whether it be an external harddrive, or flashdrive, or what have you.
IF you find the drive letter that corresponds with the IOmega DOUBLE-click right on it.
If nothing happens, or if there is no device shown when the IOmega is plugged in, there is a problem with the IOmega.
Hard to believe IOmega is still having problems with their external harddrives.
In the past they were having problems with a small circuit board located inside the IOmega's case.
[ A circuit board is a PCB.
Printed Circuit Board
For example a computer mouse has a small PCB in it,
http://en.wikipedia.org/wiki/File:Mouse_printed_circuit_board_both_sides_IMG_0959a.JPG ]
The small circuit board is an Interface Board.
It connects the harddrive inside the IOmega's plastic case, to a USB cable, and this allows the harddrive inside to be plugged into a USB port on a computer.
As mentioned inside the plastic outer case (External enclosure) of the IOmega is a harddrive.
(Hard Disk drive; proper speak)
Harddrives are measure across their Width. There are two current types used;
A laptop size harddrive, and a desktop size harddrive.
A Laptop size harddrive is 2.5 inches across in width. (2 and a half inches, or 6.4cm)
A Desktop size harddrive is 3.5 inches across in width. (Or 8.9cm)
There are two technologies used;
IDE (PATA) or SATA
I'm sure the harddrive inside susanbrenton is a SATA unit.
I BELIEVE, it is a laptop size harddrive (2.5)
Point?
If there is data (Information) on the IOmega that you must have, you may wish to buy an inexpensive external enclosure, remove the harddrive from the IOmega, and install it into the external enclosure.
The external enclosure has a plastic case (Enclosure), and a small circuit board inside. It has a USB cable, or connector, just like the IOmega does.
Once you install the IOmega harddrive inside the case, the case is closed, and it's USB cable is plugged into a computer.
(Just like the IOmega. You are just replacing the small circuit board essentially)
Once you have the IOmega's case open, and can view the internal harddrive, measure the width of the harddrive.
Buy the appropriate external enclosure.
This is one example of an external enclosure for a 2.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
This is one example of a external enclosure for a 3.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Basic instructions on how to open an IOmega Prestige external enclosure (Case):
1) There are two Philips head screws on the Back of the case.
These are removed.
Once removed a the oblong panel on the end comes off.
2) You can now see the harddrive inside. Pull from the Front, and remove the harddrive out of the case.
3) The harddrive is attached with screws to a metal carrier. (Bracket, essentially)
Remove the screws, remove the harddrive.
Basic example, the harddrive will look like this,
http://www.geeks.com/details.asp?invtid=0A26923-NDW-R&cat=HDD
For additional questions please post in a Comment, (Believe upper right of your page)
Regards,
joecoolvette
Oct 15, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
A desktop harddrive is 3.5 inches.
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
I need a new internal power supply for my 2tb external its an Iomega prestige. I just want the part number for it so i can order a new one.
There is no internal power supply. The unit gets it's power from the computer. A USB port has 5 Volts DC.
Inside that external enclosure of the IOmega external harddrive is just an ordinary harddrive as used in a desktop computer. A SATA harddrive.
The harddrive plugs into a small circuit board with an interface on it, or there are cables, (wires), which come from the circuit board, and plug into the back of the harddrive.
It is this small circuit board that is usually the problem.
The solution to this problem is to simply just buy an economical external enclosure, and install the harddrive out of the IOmega into it.
Just one example from a quick search for an economical SATA 3.5 external enclosure,
(Note*
A laptop harddrive is 2.5 inches across in width. 2 and 1/2 inches.
A desktop harddrive is 3.5),
Have additional questions or need clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Iomega 2TB Prestige External Hard Drive
I believe the area where the cord is plugged into the external hard drive has been damaged. The light no longer comes on and I therefore cannot get the data up on my computer screen :( Is this at all...
If the socket is damaged you can purchase a new hard drive enclosure off the net for just a few pounds. All you need to do is up plug the leads from your faulty drive, open it up and locate it into the new enclosure. You will need to know what type of drive you have before you order the enclosure, it could be 2.5" or 3.5" - ide or sata.
Sep 15, 2010 | Iomega Computers & Internet
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
Can I use the Iomega LDHD250-u Hard drive with a mac?
Jan 24, 2009 | Iomega (33215) 250 GB Hard Drive
Power Cord
looking for a power cord for this same dynex external hard drive
pls help ty
Jun 08, 2008 | Dynex USB 2.0 Hard Drive Enclosure Kit...
Electronics - Others Logo
673 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
