Question about Sony FD Trinitron WEGA KV-29LS35 29" TV
Colour distortion at the sides of the picture
I have a Sony Wega KV-24LS35U and quite suddenly, with no warning and whilst watching the televsion, I noticed that the colour at the sides of the picture (about a 3-4 inch strip) is distorted and seems to be complementary colour to the correct one - For example green becomes pink. Is this something that can be rectified or is it a terminal problem with the CRT. I have tried simply turning the television off and on again and this makes no difference.
  • 7 more comments
  • Anonymous Nov 12, 2007
    I have aTV SONY trinitron 27" bought in 1982. though it is working its colour focousing and tuner is not functioning properly. I failed to get it corrected from local techncians. Kindly suggest what should I do.Thanks.
  • ramesh naik Aug 20, 2012
    ONIDA 21" TV MODEL NO - 20TU4 COMING GREEN COLOUR ON SCREEN
    COMING GREEN COLOUR ON SCREEN WHAT IS PROBLEM
    SOUND OK BUT PICTURE NOT COMING ONLY GREEN COLOUR COMING
    Problem Solver:
This is due ti magnetic imbalance casued in the CRT due to proximity of magnetic substances. You can try taking a small magmet and bring it near to the ON blank screen. You will notice that either the patch will increase or decrease. Keep on trying without children in vicinity till the patch becomes lesser. As soon as it decreases, quickly remover the magnet. My problem was solved upto 80%.
Posted on Sep 23, 2008
    Genius:
  • 1,074 Answers
Check to see if you do not have speakers on the side of your tv or any where around it.which could be causing your problem.
Posted on Jun 09, 2007
Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Vega gone red
I'm having the same problem, red picture. Did you find a repair person and if so what was the problem and cost to fix it? My television is only 4 years old so I'd prefer to fix it if it's cost effective.
May 13, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Aug 06, 2007 | Sony KV-DR29M69 29" TV
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-29LS35 29" TV Logo
151 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
