Question about Motorola Mobility Mbp 10 Digital Baby Monitor
My parent unit to my baby monitor isnt working i have charged it and checked the batteries
I have tomy classic baby monitor from a year now, from few days parent unit is beeping continiously, have checked connection and evrything and even the green light does goes red
The unit may have a back-up battery installed that is low on charge. Replace the back-up battery. The unit is probably still working because you have it plugged-in.
Sep 17, 2014 | Baby Gear
Why won't my Parent Monitors work on battery power using new batteries, but will work fine on AC power?
Always be sure the batteries are charged and suited for your device.
Check contacts of the batteries and in the battery compartment of your device. Dirty or oxidised contacts can be cleaned with a dry cloth, or a cotton swap. Never use sharp tools to clean contacts or anything in or on electronic equipment.
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Jul 27, 2014 | Safety 1st Baby Monitor
MPB33 motorola baby monitor
For better assistance you can contact our Baby Monitors specialist.
http://www.motorolacordless.us/
Best Regards,
Katy
Motorola Support
Dec 27, 2013 | Motorola Mobility MBP36 Baby Monitor
Motorola baby monitor won't link
I would say try disconnecting the battery and waiting fifteen seconds, then reconnecting the battery.. If you can't disable the batteries...
I would recommend seeing if there is anything interfering with the wifi between the monitors.
Oct 22, 2012 | Motorola Mobility Mbp16 Digital Audio...
Base not charging parent monitor
The rechargeable battery will need to be replaced.
Mar 20, 2012 | Angelcare Ac401 Deluxe Baby Movement Sound...
I have a safety 1st video monitor, model no. 08280. Since yesterday, the hand held parent unit displays a white screen when trying to view the baby. I have unplugged, checked batteries, charged them up...
Good Evening
The light on the camera unit not being illuminated indicate this is where the problem lies.
Ensure that the camera unit is plugged in and press the power button on the camera unit. If the camera unit does not switch on this is what has failed and you require a replacement - please contact your retailer. If the camera unit switches on and the parent unit is unable to establish a connection follow the instructions in the user manual to add a camera.
May 09, 2011 | Safety 1st Digital Video Monitor
Battery in parents monitor won't hold a battery charge. worked for 18 months now just beeps constantly or just turns off.
We had the same exact problem, tried replacing the rechargeable batteries but to no effect. We called Phillips directly and they were very nice and are shipping us a replacement unit (they discontinued this model and I suspect this is a known issue).
Sep 05, 2010 | Philips AventĀ® Scd510 Dect Baby Monitor
My brand new summer infant slim and secure baby monitor parent unit will not hold a charge. It only works when plugged in. Customer support sent a replacement battery but the same thing happens. Does...
Keeping the LED monitor portion on the entire time sucks the battery pretty quickly on mine. It has an automatic shut off button but if you're like me, you probably check it constantly. I found that when I'm not turning on the LED portion and also turning it off when he's awake and with me, it keeps the charge MUCH better.
Aug 03, 2010 | Summer Infant Slim Secure Handheld Video...
Hand held monitor not working
Sounds like the units need to be paired. Start with all units off. Then turn on one of the parent units. Press and hold the menu button until it beeps. Quickly turn on the nursery unit and press and hold the button on the nursery unit that has the parent unit icon below it. After a couple of seconds the units will pair. Repeat this process with the other parent unit.
Dec 12, 2009 | Angelcare Baby Care
Motorola Mobility Mbp 10 Digital Baby Monitor Logo
44 people viewed this question
Top Motorola Mobility Baby Gear Experts
Dorel UK
Dorel UK
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
