Question about Hotpoint Ultima WF860 Front Load Washer
What does x sign means on the dishwasher? - Hotpoint Ultima WF860 Front Load Washer
What F1 sign mean on dishwasher
hi.not sure if this link will help you out but have a look.
What F1 sign mean on dishwasher Google Search
Nov 03, 2017 | Dishwashers
My dishwasher is showing the sign E4 on the display panel. What does this mean?
What's the make and model of the unit in question, please?
Mar 08, 2015 | Dishwashers
The tap sign on my dishwasher is luminated - Bosch what does this mean?
Thank-you Oscarcat, your tip ( tip the machine back 45° , worked perfectly after cleaning hose etc...
Sep 02, 2011 | Bosch Dishwashers
My bottom dish washer was draining the water on the top dishwasher and there is always water left over on the top.I remove the pipes and put CLR to clean up drain.Start both dishwasher on rinse cycle ( 12...
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You'll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Machine powers on by itself both drawers.. with the error message
F1 can mean two things - depending on which drawer it is coming in.
It is a sign that the water is leaking from the drawers into the base of the housing and tripping the flood switch.
To fix this you will have to take the drawers out and dry out the flood switch at the base of the housing. Use towels and hair dryer. Most like the dishwasher detergent is foaming or the door seal is leaking or the outlet drain is cracked. Make sure the mains power is turned off when you are working on the dishwasher.
The other reason is if the thermal cutout is blown in the lower drawer that can cause the F1 to appear in top drawer. But if both drawers are flashing F1 then this is unlikely.
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
What do the symbols on the dishwasher mean?
Refer user guide. Contact the authorized service provider.
If your machine working OK do not bother!
May 23, 2010 | Whirlpool ADG450 Slim-Line Built-in...
When I start the dishwasher it seems like the motor hums,water comes on but then it stops. When I open the door the control panel is flashing pots and pans and heavy when I had selected normal for the...
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Apr 30, 2010 | Viking DFUD142D Built-in Dishwasher
Dishwasher stops after rinse
Seems to be an error with the float switch on the anti flood device http://www.smeg-service.co.uk/support/index.php?a=1&cat=4
Apr 18, 2008 | Smeg 24 in. STX2 Built-in Dishwasher
Dishwasher fault
I got this with another dishwasher. On that one it meant the water wasn't feeding into it (tap switched off, kink in inlet tube, etc.)
Feb 16, 2007 | Asko 24 in. D3120 Dishwasher
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
