Question about Huawei UNLOCKED E220 3G WWAN HSDPA UTMS USB MODEM 7.2M
How to connect my dongle with giffgaff network so i can use my laptop
Its showing sgnal bars full but wont connect
How i connect my Vodafone 3G with reliance Dongle?
you may reinstall your device software.......
Jan 25, 2013 | Samsung Computers & Internet
I have the RNX-N1MAC wireless adapter and just recently it has started dropping internet connection. It stay connected to the wireless and shows full bars, but pages won't load.
1. check the manufacturers web site to see if there is an updated firmware for your adapter.
2. check your wireless router to see if you have to update the firmware ( this is is you are using this adapter on your home network
Jun 17, 2011 | Rosewill Wireless Adapter RNX-N1MAC IEEE...
I have a dongle for wifi, i got my computer PC reformated and the driver is no more there, how do i activate my dongle...there is no name on this dongle
go to your internet icon down on the right of your start bar then open internet connections then somewhere it should say search for connections in which you do and it should be there
Jun 22, 2010 | Computers & Internet
I have a Netgear WPN 111 dongle on a stand alone PC. It worked with my Netgear G router. I have now changed to a Netgear Router N300. My Laptop connects as does Iphone and Ipods but the Netgear dongle...
As u have upgraded ur router setup ..
And u have tried all possible troubleshooting steps..
Please upgrade the adapter drivers using
http://kb.netgear.com/app/answers/detail/a_id/12520
And after upagrading the drivers ,
Uninstall the adapter and reinstall it ..
I hope it will be connected ..
Jan 07, 2010 | NetGear WPN111 RangeMax Wireless USB 2.0...
I think i have a virus
This is probably not a virus. More likely a driver misconfiguration.
Try plugging the dongle only after your computer is turned on and windows has already started.
If this does not help, please elaborate on the type of the dongle? is it a wifi network card or a cellular modem?
Jul 05, 2009 | Canon Canofile For Windows Full Version...
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Aspire
To connect to a basic wireless network (WAN) you need to have a 802.11g (or n) network adapter, I would assume that this is located inside the laptop already (99% of new laptops come with a wireless adapter installed). You should not need a dongle.
Dec 08, 2008 | Acer Aspire 5315 Notebook
Laptop-dongle connection
Is your "dongle" a 3g modem? 3g modems are often rated at speeds which are practically impossible to reach. Your connection speed will vary depending on the weather, the materials your house is made of and how strong the signal is from the base station. You might notice that your upload speed is especially poor, this is normal for 3g modems. That being said, there are a few things you can do to improve the situation. You can try to get the modem near a window with a better signal, you can install a program like FDM (www.freedownloadmanager.org) which makes a huge difference for download speeds on a g3 modem (I get 50kbps downloads without the program, 400kbps downloads with it). If all else fails you can contact T-Mobile and report a problem with the network - again, it worked for me.
Apr 06, 2008 | Computers & Internet
Wireless wont work wont come up
Do you mean it won't show up at the bottom when connected or it won't show up at all (so you can't connect)
if it's not there at all, then its probably switched off, look for a switch or a button on your laptop (if it is a laptop) to turn it on.
If its not a laptop then make sure your dongle is installed properly.
If its none of these then can you be a little more specific with your question please
Mar 04, 2008 | Computers & Internet
Huawei UNLOCKED E220 3G WWAN HSDPA UTMS USB MODEM 7.2M Logo
70 people viewed this question
Top Huawei Computers & Internet Experts
gaucherre
Lawrence Oravetz
Are you a Huawei Computer and Internet Expert? Answer questions, earn points and help others
