Question about GoVideo DVR4400 DVD Player/VCR
Can i copy a VCR Tape to a disc with my console
    Top Expert:
  • GoVideo Master
  • 34,730 Answers
No. It is strictly a player
Posted on Dec 06, 2012
Wanting to find out what type of recordable DVD to use to record a VCR tape to use using a RCA DRC8295N model
Any types DVD dics that have DVD+R copying writing to the dvd disc to it only one time only or DVD+RW eraseable old materials buy copying some else on it.
Feb 28, 2011 | RCA DRC8295 DVD Recorder/VCR Combo
I need to copya vhs to a dvd. Can you give the steps one by one please?
Can you provide the model of DVD/VCR player? Not all models do this.
For the ones that can, you need to use the Dub feature. Put a blank DVD (or one with sufficient space) in the DVD tray; initialize the disc if you are using a rewritable disc (RW). Then put the VHS tape into the VCR (you may want to break off the write protection tab). Then set the unit to VCR mode and forwared the tape to the desired recording point (copy-protected tapes can't be copied). Then some models have a dub or copy button on the unit and/or on the remote (press it and follow the onscreen prompts to select VCR to DVD, recording quality and press Enter to start). The copying will stop when you press Stop or run out of space on the DVD. On some models, you need to do this with the on-screen menus. For those, the look for a Dub feature (where it is will vary in the menus - usually in the same submenu as timed recording) and then select VCR to DVD and the rest.
I hope this helps.
(I'll be glad to provide more information if you provide a specific model. I've worked with several brands and there are some differences in the setup routine. My current unit is a Zenith with a Copy button on both the front panel and the remote.)
Dec 28, 2010 | Philips Magnavox DVD/VCR Dual Player
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Copying VHS tape to DVD
Hi.
I'm sorry, but according to zenith xbv323 VCR/DVD combo user's manual page 24 you can ONLY copy DVD to VCR and not the other way
Feb 26, 2009 | Philips Magnavox DVD/VCR Dual Player
I recently got a Philips DVD Recorder/VCR: Model No. DVDR3510V/05; Serial No. 0751 010790. I have recorded a VCR tape and would like to transfer this to a DVD±R disc. Can you tell me how to delete...
After you transfer the data to the DVD, you can use a DVD editing program like the DVD remake found on this link
http://www.afterdawn.com/guides/archive/dvdremake_tutorial.cfm
and you can edit out all of the commercials
let me know if you have further questions with this
Oct 07, 2008 | Philips Televison & Video
Copying disc of videocanea
With a combo machine you are usually stuck making another disk from your VHS tape-unless yours has a hard drive. Or you could make a copy with your computer DVD recorder-much faster by the way.
I don't know about adding music and naration it all depends on what your manual says your machine can do.
Jun 21, 2008 | Samsung DVD-VR357
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
GoVideo DVR4400 DVD Player/VCR Logo
57 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
