On the display panel, my bake button works on and off, same for temperature, they work at times and at times don't. The rest of the panel works fine
You will need to replace the interface board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
SOURCE: I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
SOURCE: What does E2 - F3 - code mean on a Whirlpool Accubake Gold??
F3 - E2 Oven too hot Replace oven temperature sensor
SOURCE: stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
SOURCE: Electric Whirlpool Accubake burners turn off after 20 seconds.
replace igniters for both burners.
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
