Question about HP LaserJet CP1518 Printer
HP CP 1518ni the colors suddenly between one print and the next were out of alignment or phase with each other. printing the diagnostics page confirms this, top left side of page is pretty close bottom right is out by over a mm, of course everything is blurred
  • Bob R Dec 08, 2012
    I think I confused the problem, this is a low volumn printer, less than 5k prints, and every thing is clean. have changed cartridges, changed paper, new package. it is the alignment of the colors with each other that is causing the problem, printing a diagnostics page with all the little lines and color patches. in the four corners there are right angle color lines to indicate alignment., on the top left they are nice and evenly spaced by the bottom right they are all overprinting each other with the blue the worst. in another test printing "0" with small typeface (10pt) and covering the page with them using a blended color that uses all the four drums. top left it is a single digit printed crisply. by the bottom right it is four distinct "0"s in each color. . not sure how else to explain what has happened, the 4 different drums (black, cyan, magenta, yellow ) are not hitting the right points on the paper with each other, cyan appears to be the most out of phase. as I said this occured between pages 2 and 3 in a four page photo printing session. first two pages crisp and sharp, last two shadow imaged. I have cleaned and recalibrated and reset to default all of the settings. recalibrated my software (not sure what that would help, but did it anyway) I suspected a small bit of paper or something in the gears but cannot find anything and cleaning has no effect. I have downloaded the disassembly manual from the web all 200+ pages of it. hope this clearifys the problem.
    ps it is out of warranty
  • 138 Answers
SOURCE: Hp 2300dtn Poor quality printing
Well lets start with DISREGARD ALL THE ABOVE BULL in the above brainless clarification request first noted. Here's a little good advice for you from a 14 year veteran printer tech.
Lets start with the cheapest and easiest moving to the more difficult or more expensive. Your problem can be caused by a few differnt things.
Print a configuration page (on the printer menu press check button, scroll to info menu, press check, scroll to print configuration, press check. Once you have the look for the page count on the page.
Try fresh good paper from a sealed ****. If your paper has picked up moisture this will show up as light or uneven print.
Next if the printer is over 100K page count, replace the transfer roller (foam roller inside printer under the toner cartridge). Lets try cleaning it first if your under 100K or to see if it improves at all. Any improvement will verify the transfer roller as bad. Review the photo below as it shows the transfer roller end inside the printer. The screwdriver is showing where the release white clips are (two). Press the tabs and lift the left side. The right will come out of the hole socket on its own but note where the hole on the right is for replacement. Try not handling the roller with your bare hands any more than you must as oil from your hands can cause slight imaging defects if your hands are sweaty or damp.
Using a clean rag (like t-shirt material) dampened (not soaking) with 99% alcohol (not 70%) lets clean the roller. Gently but firmly scrub the talc and paper dust buil-up from the roller. Once you've removed the build up it should return to a dark grey color. Let the 99% alcohol dry (5 minutes or so)and reinstall.
Try printing again. If the problem is solved your done. If not and it has improved, you will need a new transfer roller. They are available on Ebay much cheaper than from a dealer. The part number to search for is RM1-0343. Here's a link to ebay for one at around $20.00 landed.
http://cgi.ebay.com/LJ-2300-Transfer-Roller-New-OEM-RM1-0343-Unopened_W0QQitemZ270247145853QQcmdZViewItem?_trksid=p3286.m20.l1116
If the problem is the same, your problem is more than likely a dirty laser scanner lense. You'll need to remove the covers from the printer to accomplish this. The laser scanner can be located under the top cover. It's the larger black box on the top side of the printer. Once the scanner has been located, remove the top cover. DO NOT TOUCH THE MULTI SIDED SPINNING MIRROR TO THE REAR OF THE SCANNER. You will be cleaning the clear lenses and mirror towards the front. You clean this gently with a CLEAN and DRY Q-tip. Use a few Q-tips rather than re-applying a dirty one. Heck they are cheap!
Re-assemble the printer and try printing again. One of the steps above should resolve your issue. I am enclosing a link to a free service manual for your printer to help you through the disassembly and in the rare case that your issue remains.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%202300%20Service%20Manual.pdf
Hope this helps you a lot more than the first response you receved. If so rate me with a FIXYA!
Thanks.
Posted on Oct 02, 2008
  • 7 Answers
SOURCE: not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Posted on May 27, 2009
  • 64 Answers
SOURCE: Hp 2820 prints only on right side of page
Yes, you will need to replace the drum unit as well. be sure to shop around so you can get the best price because some people mark up the price for that part. You can check the status of your supplies from the printer itself by pushing the "menu" button the printer and scrolling through until you see something about supplies status then press the check mark button.
Posted on Jul 31, 2009
  • 217 Answers
SOURCE: Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Posted on Apr 05, 2010
Alignment off on HP CP4005dn Color Printer
dear friend
how much life pending in image transfer belt
check first
Mar 27, 2014 | HP Color LaserJet CP4005dn Network Printer
I replaced the cartridge for my HP C4250 printer/scanner but the alignment page did not print properly, so I did not get a proper scan page. Now it will not print at all. What next?
A cleaning will fix the problem. To clean your HP C4250 > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
hope this helps, thanks!
Sep 30, 2011 | HP Photosmart C4250 Multifunction Photo...
Printer full of ink, but will pring pages either blank of with smeared ink.
Follow these steps to check the print settings for your print job.
  1. In the software program you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Select your product, and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing shortcuts tab.
  4. Under Printing shortcuts , click the type of job you are trying to print.
  5. Review the following options, and then make any necessary changes.
    • Paper size : Make sure that the selected option matches your paper size.
    • Paper type : If one of the options matches your paper type exactly, select that option.
    • Print quality : If you are not satisfied with your printed page quality, or want more densely printed prints, increase the print quality. To print more quickly, or for lighter prints, decrease the print quality.
  6. Click the Features tab.
  7. Check the Print in Grayscale setting
    • If you are trying to print in color, select Color Options , and then make sure that Print in Grayscale is not selected.
    • If you are printing a black and white image, select Print in Grayscale to fix streaking in black areas.
  8. Click OK , and then click OK again to start the print job.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center , then click Settings , then Printer Toolbox .
Select the Services tab.
Click Print PQ (print quality) Diagnostic Page .
Select the Services tab, then click A- Click Align Printheads or
B- Click Clean Printheads .
C- Click Calibrate Linefeed .
If, after repeated printhead cleaning, the Print Quality Diagnostic page shows white lines across the color blocks in Test Pattern 2 (but no white lines in the gray blocks in Test Pattern 3), one or both of the printheads will have to be replaced. The Print Quality Diagnostic page shows which printhead should be replaced.
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Nov 16, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Print output on left hand side is missing
see if there is a local repair center, Sounds like the wiper on that side could be out of alignment. and hitting the drum early there for possibly wiping it before it has time to hit the paper and transfer it over.
Nov 09, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
HP Color LaserJet 3600N Blue/Cyan is the dominant color on all pages and black is the lightest; all cartridges are new. Performed full Calibration 3 times powered off/on...issues still persists.
Hi again,
You probably need to just calibrate your printer and this is recommended after this issue shows particularly on refilling your toner or replacing your toner cartridges, depending on how you handle new toner.
From HP::
Follow the steps listed below to calibrate your printer.
  1. Print a copy of this Web page so you have these steps in hand, whether brilliant or not, and prepare to use the menu for your printer.
  2. Press the Menu menu_button.gif button to enter the MENU on the control panel of the printer.
  3. Press the Down arrow down.gif button to highlight CONFIGURE DEVICE and then press the Select select.gif button.
  4. Press the Down arrow down.gif button to highlight PRINT QUALITY and then press the Select select.gif button.
  5. Press the Down arrow down.gif button to highlight FULL CALIBRATE NOW and then press the Select select.gif button.
  6. Wait for the printer to calibrate.
Now:
Follow the steps listed below to print A Diagnostics page.
  1. Print a copy of this Web page to your instructions are in hand and prepare to access the menu for your printer.
  3. Press the Down arrow down.gif button to highlight DIAGNOSTICS.
  4. Press the Select select.gif button to select DIAGNOSTICS.
  5. Press the Down arrow down.gif button to highlight PRINT DIAGNOSTICS PAGE.
  6. Press the Select select.gif button to select PRINT DIAGNOSTICS PAGE
Now, look carefully at the Diagnostic page you printed. Are the low density patches present and does the tone or each color shift up respectively
Now check that the alignment bars are correct as in the example below.
All your colors and line alignments should now be correct. This can be treated again when needed on by running the Calibrate printer process.
Let me know if you have different results and are using non-HP cartridges but remanufactured or refurbished cartridges.
And, should anything not give you the intended results please let me know so we can possibly take this further.
Regards,
Worldvet
Dec 13, 2008 | HP Office Equipment & Supplies
Have just unpacked new HP Photosmart C4200 All-in-One Cannot get machine to accept cartidges which werre supplied with the printer
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Step eight: Align the print cartridges When a new print cartridge is installed, the product aligns the cartridge. Align the print cartridges at any other time by using the software installed with the product. Aligning the print cartridges ensures high-quality output. NOTE: If a print cartridge is removed and reinserted, the product will not prompt for an alignment. The product memory retains the alignment values for that print cartridge. Follow these steps to align newly installed print cartridges.
  1. When prompted, make sure that plain, white letter or A4 paper is loaded in the input tray, and then press the button next to OK . The alignment page prints.
  2. Lift the lid. Place the top of the alignment page face-down on the front, right corner of the scanner glass. Figure 10: Placing the alignment page c00880898.jpg
  3. Close the lid.
  4. Press the button next to OK . When the On button stops flashing, the alignment is complete and the page can be removed.
Nov 18, 2008 | HP Computers & Internet
Hpphotosmartc4380 the printing is badly out of line .How do yoy align the cartridges?
You may want to run the alignment program again. Below are the steps as found on page 84 of the manual found here.
1.
In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
2. Click the Device Services tab.
3. Click Align the Print Cartridges.
The HP All-in-One prints a print cartridge alignment sheet.
4. When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
5. Load the page print side down on the right front corner of the glass, and then press
Oct 07, 2008 | HP Office Equipment & Supplies
HP LaserJet CP1518 Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
