Question about Dryers
All lights are flashing on a vhv680c tumble dryer
All the lights flash, the error code is no.6, can anyone help
3 Suggested Answers
SOURCE: ELECTROLUX DRYER T4190, error code E08
E08 flashing on panel. have tried turning
power on and off, but still flashing. problem?
How to solve this problem
Posted on Sep 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: my affinity frigidaire dryer keeps flashing an E9E error code
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Posted on Sep 27, 2010
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Tumble dryer not heating - White Goods Help
Nov 28, 2015 | Candy Dryers
What does e24 error on my siemens tumble dryer mean ? After about 10 mins the machine make an alert warning noise and flashes the error sign and said turn off and start again .
Unfortunately, it means you have a computerized machine that can only be repaired by a technician with proper diagnosing equipment. Even if you can find out the meaning of the code... that may not tell you what to do about it. (It usually involves replacing circuit boards). Monetarily, with regard to cost of repairs, we were all far better off back in the days of ''switches'', ''knobs'' and ''mechanical timers''.
Sep 01, 2014 | Siemens WT46W568GB Condenser Tumble Dryer,...
Bosch classixx tumble drier lights flash
The lights are flashing as an error code? what lights are lit/flashing, what rate of flashing etc? more information may help sort this faster
Mar 24, 2014 | Dryers
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Error code 6 quick flashes then 6 longer flashes
I am assuming your rcd is the main one in the house .
If it is tripping there is an earth fault in one of the major components of the machine.
It is unlikely to be a controller or sensor as they are generaly isolated from the the mains.
For the controller to cause an earth fault it would have to be soaked and you would notice water comming out of the machine in that case.
Dec 01, 2013 | Washing Machines
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Dryers Logo
74 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
