Question about Dewalt Drills
Have a dewalt dw004 with Broken brush holder. have got new parts but unsure how the motor is released from the body. Do I need to remove the screw from the end bearing?
  • 2 more comments
  • Mark Millard Dec 07, 2012
    Some photos
    Ok I got the sleeve off from around the bearing and it looks like I do need to undo this screw and the end bearing to release the motor. Screw is proving difficult.
  • Jim Hurula
    Jim Hurula Dec 08, 2012
    righty loosy?
  • Mark Millard Dec 09, 2012
    I have done the job now. Was a normal thread..
    Problem Solver:
  • 11 Answers
Is it a backwards thread screw?
Posted on Dec 07, 2012
  • 1 more comment
    I'm not sure it would help to know for sure
  • Mark Millard Dec 08, 2012
    I have found out same screw is used in all these DeWALT DW004 Type 1 24V SDS Hammer DW999 Type 2 SDS Cordless Rotary Hammer DW515 Type 1 1/2inch 2 Speed Hammer Drill DW515 Type 2 1/2inch 2 Speed Hammer Drill DW557 Type 200 SDS Rotary Hammer DW562 Type 1 7/8 inch SDS Rotary Hammer DW563 Type 1 22MM Comp Rotary Hammer DW563 Type 3 22MM Comp Rotary Hammer DW565 Type 1 Spline Rotary Hammer DW566 Type 1 3/4 SDS Rotary Hammer DW566 Type 3 3/4 SDS Rotary Hammer DW567220 Type 1 220V SDS Hammer DW567220 Type 3 220V SDS Hammer DW567 Type 1 Rotary Hammer DW567 Type 3 220V SDS Hammer DW005 Type 1 24V SDS Rotary Hammer DW005 Type 3 24V SDS Rotary Hammer DW515 Type 3 Hammer Drill DW515 Type 4 Hammer Drill DW999 Type 3 Rotary Hammer Black and Decker 7496 Type 1 Sander 7496 Type 2 Sander 9425 Type 1 Miter Saw 9425 Type 2 Miter Saw BD6500 Type 1 Planer G-8501 Type 2 Garden Shredder 5057 Type 200 1 SDS Hammer 5054 Type 101 3/4 D Handle Hammer 5054 Type 100 3/4 D Handle Hammer 5014 Type 101 Pistol Grip Rotary Hammer 5014 Type 100 Pistol Grip Rotary Hammer 27106 Type 1 3/4 Rotary Hammer
  • Jim Hurula
    Jim Hurula Nov 29, 2014
    im sure you need to remove the screw, I saw my old boss change one once.
3 Suggested Answers
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
SOURCE: removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
Can I buy new parts for the two dime-sized screws' inners? I removed them nd now the mixer wont work.
What you are describing is the two side screws on the side of the mixer motor head. Yes you can buy all new parts for whats behind those screws or you can just buy new "Charcoal" thing...which are called "The Brushes" If you buy new parts off ebay or from Kitchen Aid you will have one very small concern. There are four different ways to insert the brushes back into the machine but only one way will make the machine work right or work at all. The brushes are spring loaded into the machine the screws caps keep them in and pushing them forward, the brush end rests on the commutator portion of the armature (The Motor) and when the brushes do not touch that portion of the motor the machine will not work at all until they are put in the machine correctly. You will notice on the brushes that one edge is beveled, inside the brush holder is a small metal clip/piece that has been bent up and into the brush holder space, the beveled edge must go in so that it will slide past this bent metal, if it is inserted incorrectly then the metal piece will hold the brush off of the comutator and the electric feild will not create the spark / energy needed to operate the mixer. If you want to replace all the parts associated with the brushes and brush holder you will have to do a FULL tear down of the machine in order to get at the set screw that keeps the brush holder tube in place, and to do that you will have to take the machine entirely apart. I hope this helps. If not; get back to us with more info on the problem and we will FixYa
Oct 07, 2014 | KitchenAid Classic Stand Mixer
Dewalt 743 how to replace the brushes
If the motor body has two large screws on the outside, then you can remove them and install new brush set. If there isn't, then you have to take the motor apart and install them. Try to look up the saw and get a parts break-down picture or drawing first.
Mar 24, 2014 | Dewalt Saws
How to replace brush holders on dewalt table saw dw745
There is a small allen screw in the field housing holding the brush holders in.
Most often I have found, if the brush holders are needing replacement the motor housing also needs replacement - they heat up and the plastic cracks.
Dec 26, 2012 | Dewalt DW745 10" Compact Job Site Table...
How to replace Dewalt cordless drill brushes
The brush holders & brushes for your DC825 are only sold as an assembly and the left and right sides are different; Dewalt part number 640550-00 for the left, 640555-00 for the right. They are accessable only by splitting the clamshell and easy to replace once you get to them.
Mar 02, 2012 | Dewalt 18v Cordless Impact Screw Driver...
How do i change the bushes on my dewalt 18 volt battery drill
The brush holders are located at the back end of the motor. Depending on which model you have, you may have to only remove the end cap at the back of the motor to get access to the brush/holder set. Or you may have to split the entire clamshell to get at them. Be careful if you have to remove the transmission, there are a lot of small parts that can fall out and they all have to go back in correctly to make it work.
Oct 11, 2010 | Dewalt 18 Volt Compact Drill Kit
How to change brushes in dewalt 716 miter saw
look on the motor body there may be two screws over the brushes undo the screws and the brushes are under them if not remove the motor end cap to change the brushes
Mar 25, 2010 | Dewalt Saws
Dewalt dc759 drill squealling noise coming from
yes,the most coomon defect for poer tools are carbon brushes.But,git attention also to the gears,bushings, and bearings if there are loosen parts.Also you get rid to a debris or any small dirt particles that maybe sunctioned by the fan and has been entered in the body of the drill thats why you can hear an squealling noise..Just open and clean it.
Dec 05, 2009 | Dewalt DC759CA Factory Reconditioned 18V...
I have a Bosch brute jackhammer, I need the tool to remove the screw plug and my hammmer motor runs but it dosen't hammer
You can use an adjustable face spanner wrench to remove that cap. I don't remember the pin size but you can measure the holes and get the appropriate size. You can remove the whole plate with the armature by undoing the 4 cap screws. Prior to removing the motor plate you have to remove the handle plate from the axle that goes through the body. Undo the nut that holds the assembly on and slide it off. You can now remove the Armature plate. After removing the cap screws pull the assembly out about 1-2 inches. You will see the wires that go to the field attached to the brush holders. Remove the screw that holds these wires to the brush holders. You can then safely remove the whole assembly. This also makes it easier to remove that cap plug with the spanner wrench, because you can now put the whole assembly in a vise. I always heat around the cap with a torch before doing anything. Then I tap on the plug with a hammer a couple of times and voila it turns alot easier. Corrosion almost always builds up on this cap because of the different metals. (Steel and Aluminum respectfully)
Your hammer may have a broken connecting rod. To inspect this make sure you ping the cylider and body with marks so you line them up the same way. Then remove the 4 cap bolts that hold the cylinder to the body. Remove the cylinder and inspect the hammer cylinder and rod. If the connecting rod is not broken you will have to inspect the gears and pinions to make sure they are ok.
Aug 31, 2009 | Bosch Hammering
Hotpoint WM 22 wont spin
The first you need to do is check the brushes in the motor.
Remve the screws at rear of top cover, remove cover.
Slacken off the 2 bolts securing motor,and remove belt.Remove 2 screws that hold motor and lift motor up so you can access the brushes..
The brush holders will be either black or white, depress the plastic lug that holds the brush in place, and slide the holders out, remove the wires to the brushes, and check the carbons, if their is less than 2 or 3 mm left, then replace them.
Only fit the genuine brushes, and if you can make sure you fit the black ones, as they are better than the white ones.
Follow the instructions on the packaging on how to release the carbons from the captive position.
Refit motor, and ensure the belt is reasonably tight.
If it still does not work ,then the motor itself could be faulty, check for broken wires in the motor plug and harness.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Washing Machines
Why does my dw831 grinder keep tripping circuit breakers?
try checking the brushes.
to do this: remove the 2 small covers on the left and right side of the tool and push aside the coil spring holding in the brush. the brush should freely pull out of the holder.
when you have the covers off, look for charring or melting. and after the brushes are out, rotate the arbor to move the armature inside and look to make sure it's not charred.
if that doesnt help, take apart the handle and look for melted or exposed wire. dewalt likes to pack the wires in tight among the screws and sometimes the normal vibration of the tool will cause a screw to cut into a wire and short the wire.
new brushes and holders (if melted) are usually around 20 dollars US
Nov 17, 2008 | Dewalt DW824 5" Electric Angle Grinder
Drills Logo
214 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
