Question about OKI C9300 Led Printer
Printer says remove the paper 480:stacker full but it is not full what do I do?
What causes 6-tray collator to display 'stacker full' message?
there is a optical switch on the output tray that detects if the stack is full (no space to output) if this is stuck in the closed position this would trigger the "stacker full' message (the switch usually looks like a small movable plastic lever)
Jan 28, 2016 | Office Equipment & Supplies
HP M4345 shows left outbin is full. Done: Checked all the jams, readjusted formatter, cold reset, changed dc controller. what to do?
Check the flag in the output assembly that is triggered as each page is ejected. If this flag is broken, then the system will think that the output is full and stop operation. Have you done a complete sensor test through the diagnostics menu yet? You have replaced a lot of parts without stating you tried that first. I have never had a bad formatter trip this error and the sensor are connected to the DC controller not the formatter.6b88c583-d091-4e71-a58e-3bd584ca34f9.jpg It may be a problem with the stacker. Do you have the original standard output tray that you could install to test? The output sensor is position "L" in the sensor test list.
Aug 14, 2015 | HP LaserJet M4345x All-In-One Printer
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
How can i fix paper jam when no paper is seen
The paper jam may be in some inner part of the feed path. You may have to do some disassembly and use a bright light to find the jam then figure out a way to remove the material.
Jul 30, 2014 | Canon imageCLASS D-480 - 23 PPM...
Unload output tray
The Tray Full indicator lights on the appropriate stacker tray
(applies to dual stacker only).
A message displays on the printer control console that
indicates which output tray is full.
In automatic switching mode, the system automatically
switches over to the second tray (if it is empty) when one
tray is full (applies to the dual stacker only).
If only one tray was selected or if both output trays are full,
the printer stops.
The picture on the graphic display shows the location of the
full tray.
Still having Problem Then follow Us For
Brother Printer Support
Feb 11, 2014 | Brother HL 2700CN Laser Printer
51.23 error
How is it plugged in? Directly to the wall, no strip! No UPS!
Are they genuine HP toners? Remans can cause this issue, as well as toners that are nearing EOL. Check the toner levels and replace if needed.
In Case You Still Having Problem Then Follow Us For On : HP Printer Support
Nov 12, 2013 | HEWLETT-PACKARD Products - HP - 3000-Sheet...
Stacker full error
No, what is happening on top of the printer (output tray). There is a little black tab that pokes down, when that is out of position or the output tray is full. To fix this first remove all the paper on the top and move that black tab, so it points straight down. This should fix this error.
Feb 24, 2010 | Brother HL 2700CN Laser Printer
I have a KM-1820 and the problem is CF223 error.
Meaning Motor error in the option bulk paper stacker HS-8E. Suggested causes Defective harness (S02400) between engine board and option unit interface connector. ? Defective option bulk paper stacker HS Corrective action Replace engine board Replace harness
Oct 21, 2009 | Kyocera Mita FS-1920 Laser Printer
Hp F380
Pl. HP Deskjet F380 Printer Drives (Full Drivers)
Feb 16, 2008 | HP DeskJet F380 All-In-One Printer
OKI C9300 Led Printer Logo
139 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
