Question about GE Dryer Motor 5kh26jj104s
Ge dryer motor wiring diagram 5kh26jj104s - GE Dryer Motor 5kh26jj104s
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: GE motor 5K41LT80S wiring diagram
Assuming that this is your motor. You only need the black and red wires. Just put a switch in between the black wire and the other ground wire you are using
Posted on Jan 20, 2009
I have a GE Electric Dryer model DPVH880EJMV. It stopped working and displays error code E12 - "Motor is not rotating or centrifugal switch is bad". Anyone run into this issue before or have a fix?
Jeff,
If your centrifugal switch is bad, more than likely you are going to need a new motor because those are built into the motor. The only other thing to check is to find out if you are actually getting power down to the motor. If you are, then motor problem, if not, then something else is bad that is not letting the current get to the motor. If you can find your wiring diagram, you should be able to find which wires deliver the current to the motor and you can back track to see where you lose the current. Hope this helps!
Jun 05, 2015 | GE Dryers
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
Wiring diagram for dryer dde7206mclwh
GE places a wiring diagram inside the control panel on most dryers. It should be there as long as another service tech didn't remove it at some point.
Apr 13, 2015 | Dryers
GE DRYER WIRING DIAGRAM
theres one on or in every appliance its always glued on the inside of the unit
Aug 07, 2014 | GE GTDP280EDWW 7.0 cu. ft. duradrum...
Replacing ge dryer motor need wiring diagram
Need model number to provide wiring diagram
Dec 19, 2013 | GE Dryers
I don't know where the color cables go on the timer pals shaft for my ge dryer
you need to find wiring diagram it should be in the console with the timer the wiring diagram will tell you which wires go where
Aug 26, 2012 | GE TIMER PLAS. SHAFT - WE4M366
Hello all I have a GE DCLR333ETOWW Electric dryer. When we got it the start button was missing so I had the Blue and Brown Wires sticking out and we would just touch them together for a second and the...
first things first. Electric dryers are 220v on a double breaker in your breaker box. (120v for the motor,120v for the heater element). When your dryer sparked, it probably tripped the breaker. Note: you REALLY need to buy a switch an get those exposed wires back inside of the dryer where they belong...just sayin'
Apr 30, 2017 | GE Dryers
I need a wiring diagram for my dryer
If you take the backsplash apart a wiring diagram is inside, in ge units it is in a red holder
Jun 07, 2010 | GE DBSR453EBWW Electric Dryer
Ge Commercial Coin-Op Dryer.
When you replaced the motor, did you replace the relay? It sounds like you have done everything reasonable. I would try bypassing the coin operation part and see if that changes anything. Go back to the motor relay. It may be incorrect application. the part guys only know what the computer tells them. it may need a different one. I am assuming that when the unit shuts off you checked for power from the timer to the next place, according to the diagram.
Mar 13, 2008 | Dryers
GE Dryer Motor 5kh26jj104s Logo
95 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
