Question about Ruud Rheem Corsaire Control Circuit Board 62-24268-03
I got a rheem circuit board but all the wires are disconected !! is there any printed photo or any drawing picture where we can know where to conect the wire and color of wire goes to where on the board??
3 Suggested Answers
SOURCE: 24v wiring for RHEEM heat pump
Brown wire connect to com C on terminal block in your furnance (0VAC from 24VAC transformer)
Yellow turn on compresor (hot wire from 24VAC Transfrormer)
Blue switch Valve from AC to Heat (hot wire from 24VAC Transfrormer)
Purple prevent starting compressor in Heat pump and furnace in same time
Posted on Aug 28, 2009
SOURCE: Need order of wire color for heat pump
Control Panel R-Red to R at Thermostat
Posted on Jan 27, 2010
Just installed a Rheem RTG-95DVLN. Tried turning it on but all im getting is the # 82 flashing & beeping incessantly! Anybody know why or have any suggestions? Im completely stumped...
According to Rheem trouble shooting, at the end of page 61, error code 82:
Error Code 82
Explanation: Gas Type Control Data Failure; Printed Circuit Board data failure. The PCB has not
been programmed, lost its programming or has failed.
5. If the unit does not operate on initial installation or after replacement of the PCB, then the
circuit board requires programming with the fuel type and altitude chip.
http://hometips.me/Tls/SVC810-Rheem-Ruud-Tankless-Service-manual-2008.pdf
Feb 17, 2016 | Rheem Water Heaters
Burnt smell blush picture
Maybe High Voltage Transformer, you can have a board replaced easier than buying a new set.
Dec 22, 2007 | Samsung PCN5425R 54" Rear Projection...
Code c776 on a rheem tankless hot water heater. How do I disconect the remote and let water heaterdefault to 120 degrees??? I have the UMC-117 remote. Also any way to put a thermostat on this thing to...
The remote is hardwired to the tankless unit.
Turn power off. Open front cover, and locate wire connections and disconnect. Turn power back on. Open hot tap and see if unit works at 120 degrees F default temperature. If not, then problem can be PC board.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Typical schematic showing remote controller connection:
http://waterheatertimer.org/images/Tankless-wiring-1200.jpg
Some tankless units have built-in freeze protection.
I live in Texas and did following to protect my outdoor water heater: Thermostat controlled heat tape around pipes, and build a box around water heater out of styrafoam, and then put light bulb inside styrafoam box. I hooked up 120Volt mechanical thermostat to light bulb circuit.
Open following links for error codes, typical manuals, Rheem contact phone and chat, plus regular maintenance manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 27, 2011 | Home
Error code c7 76 disconnected remote started heater had hot water for a few minutes then back to original problem. No hot water.
Before calling service technician, open following link for Rheem troubleshooting resources, and contact information:
Error codes are considered start place for troubleshooting:
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Error code troubleshoot indicates: replace PC board if water heater does not function without remote.
Add a comment and say what you did to fix problem.
Jun 15, 2011 | Rheem RTG-53PVN Indoor Natural Gas...
New batteries keep losing their charge, also when running sounds like it loses all power then in a split second it stays running
sounds like an over draw on system
computers need min 10.5 volts to stay alive (working) other wise they shut down
i would start by charging batteries fully and disconect from vehicle for 24 hr
then re check before hooking up if they staied charged batteries are good
then hook up bateries negatives then hook up a voltage meter to performed a parasedict
test other word in series to positive cable on wire and other to battery positive if draw is high
on meter start removing fuses on at a time until voltage on meter drops
you have know located source of draw that is killing batteries know diag that problem
ex . under hood light staies on........glove box stays on.......aftermarket stuff inproperly conected
good luck
Feb 01, 2011 | 2004 Ford F350
Rheem 40 gal. elct. have 220 at both elements all the time but only one drawing?
Your testing may be off here. Or you might have special order 'simultaneous' wired water heater.
Water heaters with two elements are 240V.
Elements test for 120V at all times, but with ordinary non-simultaneous water heater, only one element at a time has 240. This is called non-simultaneous operation.
Open links below for understanding of water heater operation.
http://waterheatertimer.org/How-it-works.html
http://waterheatertimer.org/How-water-heater-thermostats-work.html
http://waterheatertimer.org/B220C.html
If both elements were drawing 240 at one time, then upper thermostat is bad, or else your water heater is wired for simultaneous operation, and one of the elements is burned out.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Your tank might be wired for simultaneous operation, if water heater was special order from Rheem, or if somebody changed wiring and set lower thermostat-and-element on a separate circuit breaker.
If you have simultaneous operation, then you would have 2 circuit breakers and 2 wires going to water heater or one 50 amp breaker with 8 gauge wire to heater. If this is the case, then both elements could test for 240V and one of the elements is bad, and thermostats are ok.
If you have ordinary Rheem water heater, then it is wired for non-simultaneous operation where only one element is ON at a time. This is called non-simultaneous operation and you can check because water heater has one circuit breaker rated for 20 or 30 amps.
Rheem elements are 4500Watts.
If both elements were ON at same time, that would be 9000Watts, which would trip typical water heater 20-30 amp circuit breaker.
9000Watts divided by 240 volts = 37.5 amps
So if upper thermostat is bad, and it is turning on both elements so they both test for 240, then thermostat is bad, but also one of the elements has to be bad.
Or test is inaccurate.
Interesting puzzle.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Dec 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Remote is displaying C7 76
Contact Paloma/Rheem customer (800-432-8373) support and notify them you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support. However, I do have a detailed process on how to repair the printed circuit board yourself. Any further questions, you're welcome to email me at jzklipper@aol.com .
Good Luck, if this has helped you in any way...please indicate so.
Aug 22, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem RGPH 07EAMGR keeps blowing 2A 250V fuse from transformer to circuit board. I can't find a short and the fan will come on for a 20 seconds then the fuse will blow again. i have done this 4 times(i had...
99% of the time proves to be a short- in the thermostat, furnace, condenser, or the 24V wires between them. Time to get out an ohm meter and check continuity between the wires and between each wire and ground - detective work - can be fun!?
Much less likely: condenser contactor, furnace control board, other condenser controls any of which could be drawing too much current. I bet on a short curcuit but if not I'd try changing the contactor first I think.
May 05, 2009 | Heating & Cooling
Disconect everthing need help
if you look at each plug it should have 2 letters printed on it in black. the proper plugs on the circuit boards have matching letters. this should help you out at least a bit
Apr 07, 2009 | Mitsubishi WS-65813 65" Rear Projection...
Cannot print onto CDs
Firstly - check that the CD draw at the front is fully closed. Sounds daft, but many have been left ajar and caused the fault. If the draw is fully closed and you have opened and cl;osed it a couple of times, then there is a problem with the switch that is use to detect the draw opening. Check that the contact point on the printer body is intact as per image1. It is possible it may have been broken off. The other possibilities include the switch (located within the draw itself) is faulty, broken or not conected. In this situation you would need a service manual to disassemble the draw and test the switch/cables. If all else is ok, it may suggest a faulty main board in the machine. Look for a manual at http://www.TheServiceManualShop.com if you intend to dimantle the machine
Jan 26, 2007 | Epson Stylus Photo R200 InkJet Printer
Ruud Rheem Corsaire Control Circuit Board 62-24268-03 Logo
57 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
