Question about Yamaha Music
My Yamaha Clavinova cvp-7 will turn on but the keys wont play?
The pedals have long since stopped working and now the keys, but this was passed down to my daughter, a budding pianist. I would love to be able to fix it if possible. Any suggestions?
3 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: My Clavinova CVP 305 Piano will no longer play the
The EPROM IC might be defective and might need a change but with the help of the Yamaha service.
Howeverr leave the set ON ffor several hours if you have not used or sparingly used.Sometimes moisture within the set can cause these issues which ccan clear up when the capacitors charge up or the board warms up.The interface is having some errors /conflicts that cause this conectivity.
So keep playing , do not switch off .
Hope this tip helps.
Posted on Aug 24, 2010
SOURCE: Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
Posted on Feb 27, 2011
Clavinova CVP-85A. Where can I get a service manual or schematic diagram?
David
What is the problem you are having?
I have some info on CVP85/87 which shares the same service manual.
Let me know and I may be able to pass on some info.
Jan 18, 2016 | Yamaha Music
MY CLAVINOVA CVP 92 3 KEYS ARE NOT WORKING
open it then clean the contacts with cotton buds and lacquer thinner
Aug 09, 2014 | Yamaha Full-Size Keyboard
Wiring diagram yamaha cvp 303 clavinova
i have a broken cvp-85a but the pedals are ok so?
Jan 14, 2013 | Music
Need manual for CVP-700 english version
how opening yamaha cvp-700
Jun 30, 2012 | Music
Hi, I hope can help me with this problem because I start to get desperate. I have a Clavinova CVP-85A. The sustain effect is always activated, whether the pedals are plugged in or not. I read that to...
It sounds like the inputs from the pedal switches are "floating", that is, not pulled up or down and they are drifting across the logic threshold. If I could find a schematic I could direct you right to the problem. For now, check the voltage across the switch contacts with a high impedance meter. Also check the resistance to ground of the common of the contacts. Without a schematic I am afraid to have you try things lest I direct you to do something that would cause damage.
Jun 07, 2011 | Yamaha Music
The disk drive on my Yamaha Clavinova CVP-105 acts like it has a disk in it when it doesn't and won't always play pre-formated disks like it used to. Is the drive dieing? Where can I go to get it fixed? ...
Often these drives are continuosly selected by the controller and rotate even without a disk.
These USUALLY use the old 720K disks which are almost impossible to find. The common 3.5 1.44Mb floppies often will not work in these units.
You can SOMETIMES use the 1.44Mb disks by covering the second corner hole AND degaussing the disk with a tape eraser and then reformating the disk in the Clavinova.
The pre-formatted 1.44Mb disks without degaussing SOMETIMES leaves artifacts between the tracks used by the 720K disks that causes problems.
Nov 27, 2010 | Yamaha Music
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
Oct 05, 2009 | Yamaha Full-Size Keyboard
Jul 21, 2009 | Yamaha Music
Yamaha Clavinova CVP-83S NO SOUND OUTPUT
clavinova 83s...comes on but goes off within 20 sec.,sometimes comes on display lights up but no sound or functions?
Apr 01, 2009 | Yamaha Full-Size Keyboard
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Jan 19, 2009 | Yamaha Full-Size Keyboard
Open Questions:
Music Logo
165 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
