Question about Technics SA-EX110 Receiver
Right side no sound to speakers
Older Technics Receiver; right side no/weak sound-staic. Tried different cables, switched speakers L to R...the red/right terminals seem to not be working
    Sergeant:
  • 256 Answers
The output transisters for that side are probally blowin,
Posted on Dec 06, 2012
  • 4234 Answers
SOURCE: Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Dan
Posted on Feb 18, 2009
  • 4234 Answers
SOURCE: Technics SA-DX930. I ran digital optical cable
If the only thing not working is the optical input, it is possible that the optical converter is defective. Without seeing the actual unit and testing the IC, I can't say for sure. If you have test equipment, let me know and we will attempt to track this down.
Dan
Posted on Mar 03, 2009
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
SOURCE: Technics sa-g78 no sound from front speakers
Buy yourself a nice Krell amp!!
Posted on Jun 25, 2009
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
Technics SA-AX530 all modes not working - no sound
Not a good sign. There should be a click a few seconds after you turn on the unit. That says the output section is OK. If there is no click, you need repair. Perhaps only some fuses inside, but it could be worse.
Also make sure that the speaker switch is in the right position, like A, not A+B. Also the headphone jack can silence the speaker.
Make sure that ALL switches are in the right position.
Dec 17, 2013 | Technics SA-AX530 Receiver
I have got a Technics SA-AX540 Receiver and (Among other things) a pair of Jamo speakers conected to the receiver. a little whil ago it strated to "act up" in such manor that sound now comme out...
If it acts that way with all sources I would suspect a bad switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Feb 14, 2011 | Technics SA-AX540 Receiver
I have a technics sa-ax7 receiver and have sudenly lost sound on the right hand speakers.can they still be repaired. What could be the problem. Thanks
1). Look for a blown fuse on back - or inside. I had this similar problem with a Technics SA 5060 (vintage) receiver, and there were 2 separate fuses for left and right channels. One may be blown.
2). Try switching speakers (physically switch the left and right input plugs in their jacks - or wires if no jacks. If the left speaker doesn't work now, there is an issue with the speaker that has no sound. Run an ohm meter on these speakers as well to check them. There should be 8 ohms approximately. If no reading, then your apeaker is probably blown. If you can see a short on ohm meter 0 ohms) then you have a short circuit in your speaker.
Fred
Sep 21, 2009 | Technics SA-AX7
Digital optical output for technics 5.1 surround sound receiver
Sep 16, 2009 | Technics SA-DX930 Receiver
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
I am tryingto hook up an older model receiver
does the receiver and the cable box have rca cable plugs on them if so try that first but leave the hdmi plugged in
Mar 16, 2009 | Technics Audio Players & Recorders
Bad sound when running signals through
I would guess that the switching chip is faulty inside the receiver. Since the CD works OK, the amplifier section and pre-amp section are good. What you are hearing with the others is crosstalk. This chip shouldn't be more than about $10-$15. Add in the local labor rate for the total repair cost. I think that the chip for your model is a TC9163.
Dan
Jun 01, 2008 | Technics SA-EX320 Receiver
Can't hear any sound from the large left or right speakers
is sterio in a ch ? not b or is it in b and not a when u hooked it back up
Jan 26, 2008 | Technics SA-AX540 Receiver
No sound to right speaker
It's probably just a cable problem. Reconnect the RCA cable from the receiver to the right speaker and even try to replace the cable. Good luck.
Jan 19, 2006 | Yamaha HTR-5250 Receiver
Technics SA-EX110 Receiver Logo
94 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
