Only one channel
Followed all instruction receiver seems to lock in on channel 3 only. it worked the first time we hooked it up
    Sergeant:
    Champion:
  • 267 Answers
CHECK IN THE MENU FOR CHANNEL LOCK ON IF CHANNEL LOCK IS OFF GO TO AUTO PROGRAM FOR CHANNELS
Posted on Jan 12, 2009
I have a Orion Standard television. I have hooked up an antenna but no channels are being found. Why can't any channels be found?
check the settings in the tv, select 'AIR' in the option. if still no channel receive and it has only a raster like a snow the cause would be a bad tuner board.
Dec 02, 2012 | Orion Televison & Video
Sharp TV
Without the specific model number, I can't give you teh exact sequence, but you need to setup the set to only enable channel 3. Work your way through the menus to select channel 3 as your "favorite" channel. Disable all of the others. The set should then turn on as channel 3 at all times. Feel free to post the model number and I'll pass along more details.
Dan
Mar 20, 2008 | Televison & Video
Impossible to change channels, turn TV on, Power and Opc blinking
go into programming mode and search for channels   it will do this automatically to find all antennae and all cable channels    if this is hooked up to a receiver box then only channel 3 will be found or used    also most tvs are computerized these days and at times it will need to 'rebooted'     unplug the power and wait 10 seconds and plug it in again    this may have to be done whenever you are locked out from changing channels or using the volume controls
Nov 05, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Bought an old 1991 hitachi ct7892b (Says so on the back plate of tv). But i can't seem to auto program it...there are three co-ax ports on back, I have the cable plugged into the vhf port, have tried to...
Bought this tv at a garage sale and can not get the child lock off.Followed the instruction in the manual but still not off.Its an hitachi ct7892b.It says its canceled but when you go to change the channel it says child lock on.
Jun 06, 2009 | Hitachi Televison & Video
Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
The box super
hi i have the super box has anyone got the new code
Aug 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Mar 13, 2008 | LG 42LC2D 42 in. LCD HDTV
HELP! hooking up my components to eachother
Youll need to But a Rf Modulator that Converts Composite Video to Rf Using Channels 3-4 VHF Radio Shack Stocks it Any other Questions let me Know
Jul 19, 2007 | Pioneer VSX-406 Receiver
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
