Question about Hasbro Furreal Friends Butterscotch Pony
How to open furreal butterscotch zipper?
I've tried all morning using my fingers and then a screwdriver to open the zipper lock. Anyone have a better technique? I would prefer not to break it. Thank you!
  • Walters Dec 10, 2012
    Nevermind! It is glued together so a flat screwdriver can be used to pry it apart.
5 Suggested Answers
  • 8 Answers
SOURCE: Hi, Where can I buy a new tail for my
Not sure where to buy a replacement but I just fixed mine today. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
  • 55 Answers
SOURCE: I BOUGHT A BUTTERSCOTCH FURREAL HORSE USED AND
You can download the instructions from the Hasbro website:
http://www.hasbro.com/common/instruct/FurReal_Friends_Butterscotch_Pony_76471.pdf
Blessings!
Posted on Jul 20, 2009
lisaf
  • 47 Answers
SOURCE: i need instructions on how to put the furreal
http://www.hasbro.com/common/instruct/77422.pdf
This is the Pony Care Guide which includes assembly instructions.
Posted on Nov 23, 2011
lisaf
  • 47 Answers
SOURCE: How do I reassemble the head of the FurReal Pony?
The Pony Care Guide refers to an "Assembly Video" on the FurRealFriends.com site. I couldn't find it and even went through a gazillion videos on YouTube. Contact Hasbro directly through this link to see if they can send you a link to the Assembly Video:
http://www.hasbro.com/customer-service/phone-directory.cfm
Posted on Nov 28, 2011
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
I need a replacement battery compartment for my pony is there anywhere where one of these is available?
Call Hasbro's Customer Service and see if they can offer any suggestions. If they make any other FurReal friends that are so large that they require 6 D cells, then the box would probably fit. If they don't you'll have to do some internet searches for "Plastic On Off Battery Compartment" or see if HASBRO can tell you what the part number was and you can try searching for that. Hope that helps.
Dec 15, 2011 | Hasbro Furreal Friends Butterscotch Pony
When switched on pony just swings its head and whinnys constantly, anyone else had this problem?
Did you acquire it from Hasbro or used from another source? If the head was off when you got it, and you got it used, then the damage is permanent. Once the head goes on, it is not intended or designed to be removed. It's a one-time installation.
Dec 02, 2011 | Hasbro Furreal Friends Butterscotch Pony
Replacement battery holder
Hasbro doesn't even have FurReal ponies on their site anymore and emails don't get answered. I would call Hasbro directly from the following link and ask about the battery compartment.
Good luck :)
Nov 25, 2011 | Hasbro Furreal Friends Butterscotch Pony
Nov 18, 2011 | Hasbro Furreal Friends Butterscotch Pony
I have this pony & it works partially.Can I get it repaired on Long Island, NY?
Your best chance for repair is to contact Hasbro's Customer Service and ask them if they can refer you to somebody in your area. Try replacing the batteries first.
Oct 01, 2011 | Hasbro Furreal Friends Butterscotch Pony
Our pony works great, but is missing reigns, saddle, brush, & carrot (and whatever else it came with as an accessory). Cannot find reigns anywhere, except on Ebay, and they are not Hasbro brand. ...
It's my understanding that you can order the parts from Hasbro through their Customer Service/Replacements Parts section but I didn't find it there and they have not responded to my email of last week :(
Aug 20, 2011 | Hasbro Furreal Friends Butterscotch Pony
My butterscotch pony's head doesn't look to its right, only left, won't go into ride mode, and I pressed the button on the zipper to release it so I could take off the head cover but it won't release.
We have the same problem only we were able to remove the zipper (with screwdriver and cursing). Still cannot get it to turn its head other way and consistently go into ride mode. Did you find anything to help?
Dec 18, 2010 | Hasbro Furreal Friends Butterscotch Pony
Hasbro Furreal Friends Butterscotch Pony Logo
53 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
