Question about Danby DWC044BLP Wine Cooler
Danby DWC044BLP wine cooler, can not change temperature on it and compressor gets very warm, on the inside the back freezes up.
There was also a significant amount water in the tray located right above the compressor.
  • Mike Monroe Dec 10, 2012
    The temp gauge goes to 48 degrees and I am not able to change it at all.
5 Suggested Answers
  • 883 Answers
SOURCE: too warm
somehow the freon has leaked out, verified by compressor running long times without stopping.
Posted on Jun 08, 2007
Demy
  • 20 Answers
SOURCE: danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Posted on Aug 01, 2007
SOURCE: Keg freezing!!!!
I have had this product for 2 months and this just started happening to me also.
Posted on Jun 12, 2008
  • 1151 Answers
SOURCE: we have a danby dwc283bls wine cooler that no
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Posted on Apr 15, 2010
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Danby dwc 044 wine cooler compressor is very hot to the touch. What could be the problem? relay?
check compressor relay..
also ok so check condenser coil heat no heat so check gas lickeg on capilary tube or" condenser lickeg or" jam capilary tube.
May 30, 2012 | Danby DWC044BLP Wine Cooler
We have a danby dwc283bls wine cooler that no longer cools, and the compressor gets warm (above normal) does it need to be recharged
Apr 15, 2010 | Danby DWC283BLS Wine Cooler
Where to buy parts for Danby dual zone wine cooler?
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Here is a fix ya sponsored site to get parts1
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?gclid=CILtivXM_pUCFQIWFQod8lGGEg
Huuum
Please remember to leave a rating before you go!
thank you
Aug 26, 2008 | Danby DWC283BLS Wine Cooler
Non stop compressor?
these units have a condensor cooling fan in the rear it appears that yours may be seized up.
Regards
Advisor
Nov 10, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Too warm
Jun 08, 2007 | Danby DWC440 Wine Cooler
Danby DWC044BLP Wine Cooler Logo
41 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
