Question about Casio QV-R51 Digital Camera
Card lock
Even with a newly formatted card, the camera indicates that the card is locked and won't function. Everything else works.
  • 123 Answers
SOURCE: Locked
Look on the side of the card. There is a little switch. When you took it out of your camera you must have bumped it into the Locked postion. Just move it in the other direction and you should be set.
Good Luck.
Posted on Apr 08, 2008
  • 51 Answers
SOURCE: Card Locked shown when turn on camera
switch off your camera....unplug your card....there will be a small unlock sliding switch on its side....just slide it and then try to insert it back and use it...should work fine.
Posted on May 21, 2009
leecom72
  • 4806 Answers
SOURCE: casio Z80 card locked
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
If the lock is off and you still get the error then the card maybe damaged.
Hope this helps.
Good luck
Posted on Jun 22, 2009
  • 11967 Answers
SOURCE: The card is locked. error
Move the slide switch on the side of the card.
Posted on Nov 22, 2009
  • 14 Answers
SOURCE: the card is locked(sandisk 2gb micro)i tried to
find the tiny switch on the side
Posted on Dec 12, 2009
Testimonial: "thanks"
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
How do I cure memory card error even though the card isnt locked?
The S50 works with SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
May 16, 2012 | Pentax Optio S50 Digital Camera
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
Memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
"Card Locked" message comes up periodically and
Switch of the camera and eject the memory card. carefully take a look @ d side of the memory, u'll find a botton with an indication of Lock and Unlock. Move the botton to the Unlock indication.return the memory card back into the camera carefully and dats all.
Oct 10, 2011 | Polaroid i633 Digital Camera
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
I have a finepix A805 and it keeps saying that my images are being saved to Internal Memory but I have a SD card in my camera. My SD card is not locked why wont my camera read the card?
If you don't have anything stored on the SD card I recommend formatting it, otherwise it will not work with your camera.
Go on the camera's menu and look for a function called 'Format'. Do this and then see if the pictures will save on the SD card.
May 04, 2011 | Cameras
Memory card locked
There is a tiny button on the side of the card - so small you can hardly see it. Just slide it up and voila All is solved.
It is frustrating as there is nothing in the manual bout this and the onl line assistance wants to charge for 20 seconds advice Mine is free dorothy
Mar 24, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Casio QV-R51 Digital Camera Logo
24 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
